Follow this procedure to delete a BIOS password using the Response Code method . MY SKYPE : HAISUNG4344 >>> Be sure to keep the computer powered-on during this entire procedure. The Challenge Code issued by the BIOS is only valid until the computer is turned off and back on. <<< 1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another: Ctrl, Tab, Ctrl, Enter The computer's response should be: PC Serial No.= XXXXXXXXX Challenge Code=XXXXX XXXXX XXXXX XXXXX XXXXX Response Code= 2. CHALLENGE CODE SCREEN: 3. Enter the Response Code at the "Response Code=" prompt, and press Enter. The Response Code correct your Laptop will shown the image below : 4. Press the F2 key. The BIOS / CMOS Setup screen should appear. Follow these steps to de-register the password: 1. Press 'P' to jump to the Password field. "Registered" will be highlighted. 2. Press the spacebar to change "Password= Registered" to "Password= ". 3. Press the spacebar and press Enter. The BIOS should respond with "New Password = ". 4. Press Enter again. The BIOS should respond with "Verify Password= ". 5. Press Enter again. The BIOS should respond with "Password= Not Registered". 6. Press the End key. The BIOS should respond with "Are You Sure?". 7. Press Y. The computer will restart, and load Windows, without requesting a password. Your Laptop was unlocked Thanks for used my service , Looking forward to serving you again Professional Unlock Thinkpad ibm and Toshiba ..ect.., My Skype : Haisung4344
Toshiba Tecra Z30-A UNLOCK BIOS PASSWORD Succeed [Broken External Image]:https://www.youtube.com/watch?v=eBIdYcpe77g #Toshiba #Unlock #BiosLock #Password #Remove With #ChallengeCode - #ResponseCode Skype:haisung4344 Be sure to keep the computer powered-on during this entire procedure. The Challenge Code issued by the BIOS is only valid until the computer is turned off an... youtube.com
need to know how to bypass supervisor password z30-a please. tried entering the wrong code 3 times no joy. finding literature on this subject scarce
Toshiba Challenge Code Very expensive you can get new motherboard without bios password better than buy code
