Sony Sony sve115a11w mbx-266 216-0833002 z50cr
Discussion in 'BIOS/UEFI' started by technical, Jan 11, 2014.
  1. abhijit dey
    abhijit dey New Member
    Pls provide me mbx 266 conversion
    Sent from my ASUS_Z010D using Tapatalk
  3. abhijit dey
    Pls provide me mbx 266 conversion jpg
  5. soumen saha
    soumen saha Well-Known Member
    can anyone give the tutorial how to make mbx-266 and mbx-269
    Discrete To UMA
  7. soumen saha
    plz provide mbx-269 also
  8. soumen saha
    Discrete To UMA
    268, 269 same.
  10. soumen saha
    but u give the link for mbx-266....where is mbx-268 or 269
  12. vikram singh yadav
    vikram singh yadav New Member
    this is due to misbehaviour of ghrafhics chip of you laptop its may be amd or ati
  13. 08ifix
    08ifix Moderator
    i had converted mbx 266 from discrete to uma recently as per your images from recources purchage. all is working ok display ok gfx ok but laptop auto shutdown afte one minutes exactly. pls help. i had flash the me clear given by you already.
    check not overlook any details in the picture I provided. it will fix this error.
  15. 08ifix
    08ifix Moderator
    can you tell me how to resolve this problem mbx 266 shutdown after 70 sec after conversion pls help me.
    my email [email protected]
    pls help........
    Send me pictures you have converted. I need to check if you can do exactly as my guide.
    [email protected]
  17. 08ifix
    08ifix Moderator
    thanks to all specially to admin and aquif2368 i find the solution that is R2718 must be replaced with exact 30k resistor. the resistor already soldered is some about 40k. it must be replaced with 30k. thanks a lot again.
    Shaan khan likes this.
  18. lapcarecenter
    lapcarecenter Well-Known Member
    sir ihave changed mbx 266 graphics conversion as ur picture and display working ok. but when i install graphics driver windows will stuck and not going to desktop.
    power supply for gfx core is given from vcore supply......is it work properly by this method or pls give a solution.....
    can not install a driver or can not out LCD ?
    Send i photo Manager hoardware.
    lapcarecenter likes this.
  20. lapcarecenter
    sorry sir... what are u saying...i cant understand..
Similar Threads - Sony sve115a11w 0833002 Forum Date
Sony Bios Sony SVE115a11w, mbx-266, 216-0833002 BIOS/UEFI Jan 8, 2014
Sony SVP112A19T 1P-0134200-8011 V260 R1.1 BIOS/UEFI Aug 1, 2019
SONY CCP-1310F CCP-1410F CASSETTE DUPLICATOR ELECTRONIC DEVICE Apr 2, 2019
TV SONY KDL-32S5600 ELECTRONIC DEVICE Feb 16, 2019
Sony Walkman NW-A805/A806/A808 Tablet | Smartphone Jan 20, 2019
