IBM-Lenovo Shematic Lenovo G470 G570 La-6759P
Discussion in 'Schematics' started by laptopmodel, Feb 23, 2014.
  1. kotar
    kotar New Member
    can somebody help me ? G470 can power on only with battery. not from dc jack . can't charge battery. but plugin sign was shown on windows. where can i start to trace for that motherboard ? board id was LA-6759p
  2. 41ifix
    41ifix Well-Known Member
    I would start looking at the B + input, it is possible that the second transistor is damaged.
  3. 41ifix
    Locate the current detector resistor and in diode mode measure to see the result. What value does it give you?
  4. kotar
    kotar New Member
    thanks sir
  5. kotar
    kotar New Member
    Thanks alot sir. can you teach me where is current detector resistor how can i find that on schematic
  6. 41ifix
    LENOVO. LENOVO 2.
  7. kotar
    kotar New Member
  8. 41ifix
    It measures continuity GND to resistor, it has to whistle, since you have a short one.
    If you whistle, solder a wire in that resistor and through a power supply, inject 3.3VDC and see what component is heated in the plate.
  9. kotar
    kotar New Member
    Thanks Sir, I will try it now. Thanks alot for teach me.
  10. 41ifix
    For that we are.
  11. kotar
    kotar New Member
    IT's work amazing wow... as you say sir I change PQ302.. it's work you make me happy ...Thanks alot for your teach and help
  12. kotar
    kotar New Member
  13. 41ifix
    As far as I can help, I help! I'm glad the team works!
Similar Threads - Shematic Lenovo G470 Forum Date
Lenovo S960 shematic Tablet | Smartphone Oct 15, 2018
Lenovo P700I shematic Tablet | Smartphone Oct 15, 2018
Lenovo S680 shematic Tablet | Smartphone Oct 15, 2018
Lenovo S800 shematic Tablet | Smartphone Oct 15, 2018
Lenovo S820 shematic Tablet | Smartphone Oct 15, 2018
