RT809F programmer software release
Discussion in 'Computer Hardware Repair' started by technical, Jun 2, 2017.
RT809F programmer software release 5 5 2votes
5/5, 2 votes
    RT809F, 20170518-MultiLanguage version
    Downloads
    New Support :
    MEC1633,IT8XXX_ISP @PEB-1,IT8586E,IT8580E,28/29/39/49/50 series NOR Flash @ DIP/PLCC32/TSOP32/VSOP32/TSOP40/TSOP48 #PEB-1,RTD UART series, MTK UART series,
    ISL24837A,SM4051D,SM4053B, SW5084A, CM602, FLI32626 , BUFxxx series GAMMA IC, TPS65178 , TPS65168, MST series WP Pin pull to hign during ISP ,AT89S / ATMEGA / ATTINY series MCU ISP, SPI FLASH OTP Area R/W , S3F9454 , S3F9498 , S3F9488 , KB9012 , FLI8532 , FLI8541 , PIC12Fxxx , PIC16Fxxx , WT61P6 ... ...
    AMD platform WIN7 and above system-RT809F driver problem solution
    If you have any questions, please uninstall the original software from the 809F software's "Settings" menu and use the latest version to drive V2.12.10:
    CDM v2.12.10 WHQL Certified.exe
    DVD Version 2.18
    Only use where need:
    RT809F CD-ROM password: P52Y-9N0W4L-8S7C1K7J-6ZXIAGEKD
    Hisense file decompression password: GKFWBjs6789
    RT809F_20180831_ENG
    RT809F_20181216.exe
    • Sad Sad x 1
    #1 technical, Jun 2, 2017
    Similar Threads - RT809F programmer software Forum Date
    Review RT809F Serial ISP USB Universal EPROM FLASH Programmer Computer Hardware Repair Dec 28, 2014
    KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.5 New Version Computer Hardware Repair May 25, 2018
    Full Set KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.2 Computer Hardware Repair Jun 22, 2017
    Special ! ITE ENE IO Programmer , ITE8586,KB9012,Nuvoton,EDID + Keyboard Module Computer Hardware Repair Jun 3, 2017
    RT809H programmer software release Computer Hardware Repair Jun 2, 2017
  3. CICTECCH
    CICTECCH Well-Known Member
    Please I need RT809F software for Mac.
    No have, The manufacturer does not release it
    RT809F_20180731_ENG
    RT809F_20181010_ENG
    RT809F_20181108.exe
    RT809F_20190508_ENG
  9. 18ifix
    18ifix Moderator
    what new in this version
  10. 03ifix
    Old version give error update,Now update then remove error :)
  11. 18ifix
    18ifix Moderator
    i think is the hardware of rt809h give error ... i try this programer and give me lotoff error . read or write . for this reason i change programer to the l688 plus II no error ...
    i dont mean rt809h is bad but there some problem on the hardware ... must ifix fix the programmer
  12. 03ifix
    Rt809h?or F? i used about 2 year rt809f no problem working good or i/o use i think Svod3 is best i use Sas vert.. for i/o working good about Mec.. i use patch bios working without any error
  14. telli
    telli New Member
    thanks dear
  15. telli
    telli New Member
    thanks dear
