Review RT809F Serial ISP USB Universal EPROM FLASH Programmer
Discussion in 'Computer Hardware Repair' started by technical, Dec 28, 2014.
Review RT809F Serial ISP USB Universal EPROM FLASH Programmer 4.8 5 4votes
4.8/5, 4 votes
    RT809F dùng chép ROM cho các các dòng laptop có ROM tích hợp trong chíp I/O KB9012QF-A3,chép ROM cho KB9012QF-A4,...và các thiết bị điện tử thông dụng TV,đầu đĩa , màn hình LCD.....Dể dàng kết nối cà sử dụng với máy tính qua cồng USB...
    RT809f-Isp backup software REALTEK/RTD series external spi flash
    ACER led monitor mod. V206HQLver.Ab/spi flash software
    Log process
    RTD_EXT_SPI #ISP
    REALTEK RTD_EXT_SPI#ISP
    001: SN:2014010-02xxxxxxx
    002: Scanning VGA port with wire mode A...
    003: REALTEK series,RTD2270/2660/2261/2271/2280... , external spi flash.
    004: Current selected : RTD_EXT_SPI #ISP,Size: 16Mbits,2MBytes.
    005: ----OK---
    006: VGA wire mode: SCL: VGA--15; SDA: VGA--12.
    007: Scanning VGA port with wire mode A...
    008: SPI Flash : MX25L2005, Buffer Set to 256KBytes.
    009: Reading device......
    010: Read successfully,11.39 seconds elapsed.
    011: Auto verifying...
    012: Verified successfully,11.11 seconds elapsed.
    013: Buffer checksum: 16bit_0x408F, 32bit_0x02CD408F.
    014: 22.53 seconds elapsed.Average speed:11636 Bytes/s.
    015: ----OK-----
    Tham khảo một phải hình ảnh quá trình thao tác với IO của Biosrepair. KB9012
    socket KB9012.
    rt809f26.
    kb9012 A3. EC KB9012. red rom kb9012.
    • Like Like x 4
    #1 technical, Dec 28, 2014
    Similar Threads - Review RT809F Serial Forum Date
    MacOS Sierra Review, Release Date. Apple - macOS Jun 14, 2016
    PhotoReviewer Apple - macOS Jun 5, 2015
    Review CF360T Intelligent Mute BGA Rework Station Computer Hardware Repair Dec 28, 2014
    Review CF260 BGA Rework Station upgrade Computer Hardware Repair Dec 28, 2014
    Trải nghiệm nhanh Windows 10 Technical Preview Windows PC Oct 3, 2014
  3. farman
    farman New Member
    plz send english write plz plz ...........
  4. ankit
    ankit New Member
    kyon chinese nahi aati kya
  5. karan
    karan New Member
  6. thangdthp
    thangdthp New Member
    bạn có thể giúp mình dvd kèm theo bộ RT809 không , khi mình mua đĩa bị hỏng nhưng không đổi được vì xa quá , mình cũng không biết trong đó có gì , nhưng chắc là cũng rất cần thiết lên khi bán mới kèm theo , nếu có thể bạn up giúp mình được không , vô cùng cảm ơn . Email : [email protected]
    Không có gì trong đó đâu bạn toàn mấy file ROM LCD với tài liệu tiếng tầu. Mình có từng lưu vào máy xong lại xoá đi vì không dùng được gì. Còn phần mềm thị bạn seach có nhiều rồi.
  8. triqqq
    triqqq New Member
    Cho Trí hỏi, ngoài con KB9012 RT809F còn đọc ghi con IO nào khác không, thí dụ dòng IT 8500
    Tri
  9. Root
    Hiện tại thì chưa nhưng hi vọng sắp tơi họ sẽ update software phiên bản mới.
  10. 36ifix
    36ifix Well-Known Member
    con này giá nhịu vậy ad
  11. K-PAX
    K-PAX Well-Known Member
    hi,i need software update for me programmer flashpro 800+,
    no working whith bios chip mx25l6406e,mx25l6473e,w25q16c,chip swson...
    thanks....
  12. dimpu
    dimpu Well-Known Member
    i need help
    how to programme ite8586 IO using RT809f_peb-1
    wiring details
    current RT809 no support ITE....
  14. dimpu
  15. tranthaitung1989
    tranthaitung1989 New Member
    ISP boot error,please check the ISP wires and EC power. giúp giùm lỗi này. cấm cáp usb vào máy tinh, cài chương trình,câu 6 dây theo hướng dẩn lấy nguồn 3v từ chân 33 i/o 9012qf a4 dell 3537 , chân max câu vào max của main .lỗi không đọc được đả kiễm tra lai dây nối
  16. ChetanSethi
    ChetanSethi Well-Known Member
    25LQ64CSIG HOW TO PROGRAM WITH RT809F
    Use TL866
  18. ahmadsolo
    ahmadsolo New Member
    hi guys i have asus x553ma and want to reprogram my i/o but i can not with reprogram.i do not have the rt809f 's pin's place in rt809f setting .please help to fix my problem .my email address is.[email protected] thanks.
  20. congtrinhqb
    congtrinhqb New Member
    This rom feeder load rom the common line is currently used in the non-life laptop
    RT809F have what the pros and cons compared to Minipro TL866
  21. dnalaptop
    dnalaptop Well-Known Member
    please send firmware LED TV POLYTRON PLM24M51 ..
