MEC1633L
Discussion in 'BIOS/UEFI' started by zecabg, Feb 12, 2017.
  1. IO81
    IO81 Well-Known Member
    thanks for reply do you have solution to program MEC 1633
    you can use rt809H
  3. sherifbekhit
    sherifbekhit Well-Known Member
    pins please i cant read this mec by svod , i need points
  4. sherifbekhit
    Hi sir
    plz I need JTAG for MEC1633l on board Lenovo X240 VIUX1 NM-A091 REV 1.0
    Thanks for you
  5. sherifbekhit
    Hi sir
    Thanks
  6. 01ifix
    hi @cifam , could you please share the jtag point for this
  7. 03ifix
    Here is
    dan1200rr and 01ifix like this.
  8. mshtaq
    mshtaq Well-Known Member
    HI
    Do you have T450 NM-A251 MEC1633L jtag points, please?
    Need help please!
  10. 18ifix
    18ifix Moderator
    no need to reprograme mec1633L if its new .just soldring and on the laptop .the bios on the laptop reprogram mec automatic
  11. IO81
    so we can erase mec and power on laptop and it s done
  12. 18ifix
    18ifix Moderator
    i dont try ..but i try new chip 1633 i just soldering and i on pc . the laptop work perfect without programing mec ...... but the problem is the serial number .
  13. 03ifix
    Yes you right.New Programmable i/o if new factory programming already no need to program.
  14. bioshunger
    bioshunger Well-Known Member
    Doesn't need to program MEC
    The supervisor password is stored in a SMSC MEC1633L of a TPM chip and not in the main UEFI EEPROM.
    BIOS is married to the internal TPM chip (SMSC) and contains a unique signature of that.
    Resetting this is complex because:
    It first involves reading the BIOS and creating a full dump. This is critical as otherwise you are stuffed trying to restore any other BIOS to it.
    One has to patch the dumped BIOS binaries and inject a small UEFI program. This program will read the secure eeprom, reset the TPM certificate and password and also rewrite the secure eeprom and reconstruct all data such as writing back serial number, RFID config/UUID/Type/checksums etc.
    Flash the patched BIOS dump (this will only function for that TP btw), start the laptop, while the BIOS is loading it will execute the unlock routine in the DXE module and unlock the SVP(supervisor password) and TPM.
    Finally, write the original BIOS dump back.
    Eng.Moustafa likes this.
  15. asmshoab
    asmshoab Well-Known Member
    Where keep bios password lenovo t440 ? mec or bios ?
  16. niggar
    niggar Well-Known Member
    where i get the patch file and can i read mec1633l with rt809f
  18. niggar
    i only want to make sure can rt809f read and write ?
    yes or no ?
    no, need use RT809H
  20. rustam
    rustam New Member
    hi, can u send photo position jtag location thinkpad t540p ?
Similar Threads - MEC1633L Forum Date
IBM-Lenovo T440P with SMSC MEC1633L-AUE BIOS/UEFI Dec 6, 2018
