Macbook 12" A1534 - 820-00045-10 820-00045-A
Discussion in 'BIOS/UEFI' started by technical, Jan 20, 2016.
  1. hernan tangoa f.
    hernan tangoa f. Well-Known Member
    clear ME please 820-00045
    01ifix likes this.
  2. Haker5
    Haker5 Well-Known Member
    please add your bios i clear for you
  4. dam1inc
    dam1inc New Member
    Is it possible to Use chipmunk clip on a1534 EMC 2991?
  5. abagjery
    abagjery Well-Known Member
    Hi
    If you look on Ebay they selling them and I used one of them unfortunately at this moment I forgot the model # but I did copy and edit and write it back ,works good
  6. dam1inc
    dam1inc New Member
    thank you, i CH1341A and chipmunk easy flash but always get errors writing..i also have sofi-sp8 but havent figured out how to connect easy flash to sofi-sp8. do you know how? I saw a post that said you use sofi-sp8 to read and write, for me the only way to read/write is to desolder the chip but its a super time killer:fou: (fou)
    sorry i not Understand problem for you.
  8. dam1inc
    dam1inc New Member
    I am wondering if sofi-sp8 and chipmunk easy flash are compatible
    Sent from my SM-G955U using Tapatalk
  9. dam1inc
    dam1inc New Member
    Trying to read/write to emc 2991 without removing chip
    it problem for you, i can help....
  11. dam1inc
    dam1inc New Member
    Yes please that would be great , I have CH1341A , easy flash adapter and also sofi-sp8
    This model reads with ch1341a as micronix but it's windbond? I am able to read but erasing and writing not. Always give error as in screen shot, I used .bin from here and clear Region ME and still same thing[emoji20] 602f190d0d28418b38b882e8b41cd441. 5ebfec15822c5f73d9f1ec9665ef743b.
  12. abagjery
    Hi first you must chose ISP from device like 25q64v (ISP) and hook up chipmunk wire this port
    upload_2017-9-15_11-34-27.
    Normally I plug the power supply for the mac in and make sure has the power but computer is off after that I plug in the chipmunk on the socket and try to read after edit and writing on it make sure the chipmunk in the right direction
  13. dam1inc
    dam1inc New Member
    Aaaaah ok thank you very much!!!
  14. K-PAX
    K-PAX Well-Known Member
    hi dam1inc,you can programmer the mac,i have a1534 emc2991
    and I cant erace or write.tell me please
  15. Macfixit
    Macfixit Well-Known Member
    tel me if you have a problem i can help you white te chipmunk kabel and connector
  16. K-PAX
    yes I have problem,help me.i have ch341,and sofi
    my mac is a1534 (2016)820-00244
  17. K-PAX
    hi dam1inc,you can unlock the mac?
    JackT likes this.
  19. K-PAX
    I need programmer without desolder bios
  20. JackT
    JackT Well-Known Member
    the connection pictures are very helpfull! thanks a lot. i tried same connection with TL866 programmer but could not detect the chip correctly
Similar Threads - Macbook A1534 00045 Forum Date
A1534 macbook change serial number BIOS/UEFI Nov 2, 2018
Apple Apple Macbook Retina A1534 BIOS/UEFI Jan 26, 2018
MacBook 12" 2017 A1534 EMC 3099 BIOS BIOS/UEFI Jun 9, 2017
Macbook air 820-00165 no sound Computer Hardware Repair Aug 18, 2019
macbook pro A1425 efi password unlock plz BIOS/UEFI Jul 8, 2019
