Macbook 12" A1534 - 820-00045-10 820-00045-A
Discussion in 'BIOS/UEFI' started by technical, Jan 20, 2016.
  1. 01ifix
  2. JackT
    JackT Well-Known Member
    the best thing is to erase the disk using a live Ubuntu usb stick after you boot from that. the only problem with ubuntu is that it did not have the proper drivers for the keyboard/trackpad so i was using an external keyboard+mouse connected through a dell type-c to usb dock. if you format the disk like that and leave it in GPT partitioning table then i believe you can install windows 10 from a usb installation media.
    I will try it tonight or tomorrow and give you more info.
  3. Gasasoft
    Gasasoft New Member
    I try that with no luck. Setup not recognize SSD. I will try tonight several metods and post here my results.
  4. Gasasoft
    Gasasoft New Member
    I have no luck.
  6. Gasasoft
    Gasasoft New Member
    No SSD is OK. I successfully install Ubuntu linux. Problem is in wrong BIOS dump, but I cannot find right one.
  7. JackT
    yes i have the same problem with you. still didnt have time to check it properly again.
  9. bridx
    bridx Well-Known Member
    Hi,
    Where can I buy a new blank bios for the 820-00244 motherboard.
    Regards.
    You want buy chip this ?
    It is very rare :D
  11. Haker5
    Haker5 Well-Known Member
    mission completed
    add with backup and photo very hard job backup without serial number any want serial write to dump
    dimas30 and 01ifix like this.
  12. Haker5
    in my macbook i have serial number i special remove for any want using backup add serial number
  13. 01ifix
  14. Haker5
    you want diagrams how to connect programmer or you want pinouts
    01ifix likes this.
  15. 01ifix
    possible both for more easy , i have tl866 and RT809H programmer.
    thanks in advance.
  16. Haker5
    tahts is for tl866 tested 100% work you have two photo IMG_0089. FNMO1887.
    01ifix and technical like this.
  17. bridx
    Hi,
    The WLCSP (BGA) chip solder pads are not getting solder balls on them, I soldered thin insulated wire to the pads on the motherboard and now trying to attach a normal 200mil SPI BIOS chip to the wire, some advice on my terminations. I have tried but the machine doesn't turn on, though 3.3v is present at PP3V3_SUS.
    Regards.
  18. K-PAX
    K-PAX Well-Known Member
    HI,i programming "in circuit" 820-00045 1534(2015),but 820-0024 1534(2016)not
    I cant,i don't know what happen
  19. bridx
    I was only able to read the chip in ISP mode but writing to it in ISP mode was not sucessful. Waiting for another donor board to arrive so I can replace the damaged BGA bios.
Similar Threads - Macbook A1534 00045 Forum Date
A1534 macbook change serial number BIOS/UEFI Nov 2, 2018
Apple Apple Macbook Retina A1534 BIOS/UEFI Jan 26, 2018
MacBook 12" 2017 A1534 EMC 3099 BIOS BIOS/UEFI Jun 9, 2017
Macbook air 820-00165 no sound Computer Hardware Repair Aug 18, 2019
macbook pro A1425 efi password unlock plz BIOS/UEFI Jul 8, 2019
