Macbook 12" A1534 - 820-00045-10 820-00045-A
Discussion in 'BIOS/UEFI' started by technical, Jan 20, 2016.
  1. 05ifix
    05ifix Moderator
    without removing chip ?
  2. abagjery
    abagjery Well-Known Member
    Yes but I'm using this adapter Chipmunk Magic Easy Flash MacBook A1534 witch you can buy from Ebay
  3. Macfixit
    Macfixit Well-Known Member
  4. 05ifix
    05ifix Moderator
    Ok so now i know what to use to read and whrite dump , but how can we clean a dump for a1534 ? i want to learn. allsow how can i remove username password and icloud from console, for a A1534 , without Efi pin
    here
    https://vinafix.vn/resources/how-to-remove-password-bios-apple-add-edit-serial-number.1209/
    Unlock - How to remove password Bios Apple & Add, edit Serial...
    Manual document .pdf 1. Use tool ( TL866 or 610P ...etc ) backup BIOS has password. 2. Open BIOS use software HxD remove password. 3. Done and Programming. You need to be a hardware technical to...
    vinafix.com
  6. Jitendrakashyap
    Jitendrakashyap Well-Known Member
    any one tell me macbook air after bios programmed os was not open properly he just loading
    anyone know why
  7. K-PAX
    K-PAX Well-Known Member
  8. Macfixit
    it work on eprom reader low speed and i have made efi killer that remove efi lock 12 sec all models til 2017
    JackT likes this.
  9. K-PAX
    hi guys,i need you help.have one a1534 820-00244 with password,
    this machine is diferent a 820-00045 a1534(2015)
    the 820-00244 programming with the ch341a,and right now missing video
    someone remove password this a1534 2016 ?
    my problem is the client,the machine now no have video
  10. K-PAX
    no detect chip of bios
  11. bridx
    bridx Well-Known Member
    Working on a MacBook 12 A1534 820-00244. Am able to read its MX25L6435E ic but unable to write into it. Let me make my terminations through J6100 to confirm if it will work.
    technical likes this.
  12. Macfixit
    i can read and write the chip white out any problem ;)
  13. bridx
    Hi, could you share how you terminated the connections to the motherboard. Regards.
  14. Macfixit
    tom i make some photo i am now at custom off me repair some board its my job
  15. bridx
    I don't understand your reply.
  16. Gasasoft
    Gasasoft New Member
    Hi there!
    This is my first post on this forum. Im from Serbia!
    I have problem with one A1534 820-00045-11.
    I remove the BIOS chip from mainboard, and damage one contact on it. I buy a new one on aliexpress and look for dump.
    Found 820-00045-A and I guessed is suitable for my 820-00045-11. Programmig went without problems on MiniPro TL866CS programmer (see the picture). 20170312_213319.
    Apple power on like normal but, when I try to install Yosemite, it freeze on approximately 50% on install process. Picture below. 20170421_212133.
    I try several times. Once I heard a message "if you want english for you main language press return button". I press Return button but nothing happened. Progress bar is still on same place. I try install from USB Stick and from Internet Recovery the same thing. I sucsessfully install OSX on many Apple computers without problems but this one is my nightmare.
    My questions is:
    Is the 820-00045-A BIOS dump suitable for my mainboard 820-00045-11?
    Is there something I do wrong during intalation Yosemite on it.
    Thanks in advance!!
  17. jawaljawad37
    jawaljawad37 Well-Known Member
    you shoud not change the program you shoud remouve just password from orginal dump and reprome it
  18. Gasasoft
    Gasasoft New Member
    I know that but cannot read dump from original BIOS chip, because is damaged.
    If anybody have a BIOS dump from 820-00045-11 I would appreciate if send it to me on PM or somewhat, because I not a VIP member yet.
  19. JackT
    JackT Well-Known Member
    Hi i have the same problem with a early 2015 one. i got a ready chip online replace it ok. All OSX installations and preinstalled usb keeps crashing on loading. I think it has to do with the bios dump being for a different cpu version. We need to have a clean ME bios dump or the correct one for the same cpu to work properly. I tried by installed Ubuntu Linux and its working fine.
    p.s. We have the same programmer :innocent:
  20. Gasasoft
    Gasasoft New Member
    Thanks for the reply.
    Bios will eventually appear, do not doubt it. But we need now.
    I would be satisfied with Windows 7 or 10, Do you know how to Install those?
    The normal procedure is not possible. SSD should be formatted in MS-DOS FAT then boot from Windows bootable USB DVD, correct me if I'm wrong. Tomorow I will try Ubuntu Linux.
Similar Threads - Macbook A1534 00045 Forum Date
A1534 macbook change serial number BIOS/UEFI Nov 2, 2018
Apple Apple Macbook Retina A1534 BIOS/UEFI Jan 26, 2018
MacBook 12" 2017 A1534 EMC 3099 BIOS BIOS/UEFI Jun 9, 2017
Macbook air 820-00165 no sound Computer Hardware Repair Aug 18, 2019
macbook pro A1425 efi password unlock plz BIOS/UEFI Jul 8, 2019
