IBM-Lenovo lenovo Z510 Z410 AILZA NM-A181
Discussion in 'BIOS/UEFI' started by technical, Jun 30, 2014.
    model ?
  2. thaiya
    thaiya Well-Known Member
    lenovo z510 part board : NM-A181 Rev 1.0
    test above bios.
    no other solution I suspect not fault bios.
    check chipset.
  4. QuocKhanhLaptop
    QuocKhanhLaptop Well-Known Member
    IdeaPad Z410, Z510
    BIOS 8dcn40ww
  6. Robert123123
    Robert123123 Well-Known Member
    Hello, I have the same problem with the NM-A181. Turning on and off the auto 30s. Maybe someone knows what part of the motherboard is the problem? Change processor, and change the thermal sensor processor. I heat the GPU and PCH and Program 5 times bios with different versions of me. Nothing changes. Maybe someone has a solution to this problem?
    Need clear me
    https://vinafix.com/resources/how-to-clear-me-region.1188/
    How to Clear ME Region
    The Intel Management Engine (ME), also known as the Manageability Engine, isan autonomous subsystem that has been incorporated in virtually all of Intel'sprocessor chipsets since 2008. ... It is a...
    vinafix.com
  8. Robert123123
    I program it with clear me but nothing change.
  9. Tuyết Mai
    Tuyết Mai New Member
    Con này mình clear 100% chạy, đã test 3 con bệnh này
  10. ajamin.ali
    ajamin.ali Well-Known Member
    i have the same prolem auto shutdown
  11. 07ifix
    07ifix Moderator
    plz help me i send old bios data
    i have problem in my laptop auto shutdown in 30 sec
    nm-a181
    GD25Q16_20180315_132257_Clear me.BIN
  13. caza_nova
    caza_nova Well-Known Member
    nm-a181
    try one BIOS new anh check hardware.
  15. caza_nova
    fix auto shutdown
  17. refixya
    refixya Well-Known Member
    Hi I want AILZA NM-A181
    REV: 1.0 schematic want..sir ..thanks
  18. refixya
    Hi sir I want nm-a181 rev:1.0 ec bios.., thanks
  20. NUVOTON
    NUVOTON New Member
    ¡ayuda! Mi tarjeta NM-A181 tiene 26 pines, ¿cuál es la configuración para poder grabar el EC? Estoy probando qué es la página pero no las incrustaciones
Similar Threads - lenovo Z510 Z410 Forum Date
IBM-Lenovo Lenovo Z510 8DCN40WW Wifi/Whitelist Bios BIOS/UEFI Dec 18, 2016
Review Máy tính giải trí đa năng Lenovo IdeaPad Z510 Windows PC Dec 28, 2013
Lenovo AIZS1 LA-C582P BIOS/UEFI Oct 5, 2021
BIOS PC lenovo yoga 310s-11iap BIOS/UEFI Mar 5, 2020
