Lenovo ThinkPad X1 Carbon (5th Generation/2017) BIOS DX120 NM-B141
Discussion in 'BIOS/UEFI' started by technical, Apr 19, 2017.
Lenovo ThinkPad X1 Carbon (5th Generation/2017) BIOS DX120 NM-B141 5 5 2votes
5/5, 2 votes
    password in ec you need Programming it.
  2. MissAircraft
    MissAircraft SUPER VIP
    Hi, i have completely different question here. after pulling the black cover on the mainboard the crystal which is responsible for the IC JHL6540 broken in half . I have managed to take picture of them but dont know where to find it to fix it.
    this is better quality picture i found online which is not related to this mainboard but the crystal looks same number? Any advice would be helpful
    Mainboard used to power on and give 3 blinks but now it does nothing at all so i believe the crystal probably is damaged . i dont have oscilloscope to confirm
    need a main board same code ...
  4. MissAircraft
    so you say you need to find another dead mainboard and replace the crystal from there?
  5. MissAircraft
    i have been repairing macbook and found on the crystal showing same T250 number so i will try to replace and update you if it works . For the information only it is 25.000MHZ-12PF-20PPM
  6. MissAircraft
    well i have tried but i believe that controller is for thunderbolt so the laptop has to be fixed first...
  7. MissAircraft
    I have tried the bios files but after i have reprogram it - it just doesnt show anything but with the original bios it flash 3 times and go off. Do i need to reprogram the MEC as well?
    My laptop is : 20Hr-003HHH s/n: pF-0SXPUG
    X1 CARBON 5TH GEN says on the backcover
    Mainboard number is DX120 NM-B141 rev 1.0
    #27 MissAircraft, Mar 28, 2019
  8. MissAircraft
    I just extracted the mec and its only 195kb not 256kb . can you double check the file or it will write ok the first 195kb and the rest will not fit but the mec will ok to work?
  9. MissAircraft
    i found the problem on your Mec file. the first 2 lines has to be erased and the rest will be ok. i have uploaded yours that works (at least the mainboard gives light with that mec .bin because with your original it wasnt doing anything)
  10. krjavi
    krjavi New Member
    Hi all, i am working on this model and i cannot find the mec chip that is mentioned. any advice to where it is? is it a BGA chip?
    thanks
  11. 03ifix
    No,Have Mec1653 this board use schematic then now
    #31 03ifix, Jul 2, 2019
  12. krjavi
    krjavi New Member
    so do i need to solder to the board to read the mec1653? or remove it to scan?
    This is my first time scanning a mec chip. I mostly do 8pin chips found in MacBooks and older windows computers.
  13. 03ifix
    Solder is working why you read?Password?
  14. krjavi
    krjavi New Member
    this computer has password. I need to know how to read the MEC1653 to remove the password.
  15. 03ifix
    Above i think have pics you need to know where is connection solder your board like TMS,CLK,RMST or other if you success read then you cannot solve error dmi means serial number or other info.My suggest to buy patch is easy or work without any error.
  16. krjavi
    krjavi New Member
    which programmer do I need to read the mec1653?
  17. 03ifix
    Svod.RT809H both work
  18. andres solano
    andres solano New Member
    Como instalar mec
Similar Threads - Lenovo ThinkPad Carbon Forum Date
a cho em xin file này LENOVO THINKPAD X1 CARBON 11246-2 LGS-1 MB 48.4RQ01.021 BIOS/UEFI Jan 21, 2019
Lenovo ThinkPad T480s BIOS BIOS/UEFI Aug 15, 2019
Lenovo ThinkPad Yoga 370 - Type 20JH MB CIZS3 LA-E292P BIOS/UEFI Apr 7, 2019
Lenovo Thinkpad-T580-intel 8th Gen BIOS/UEFI Sep 20, 2018
need schematique and bv lenovo thinkpad yoga 3 2rd 17800-1 Schematics Aug 21, 2018
