Lenovo ThinkPad T480s BIOS
Discussion in 'BIOS/UEFI' started by 5umi, Aug 15, 2019.
  1. 5umi
    5umi New Member
    Hi,
    I want to flash T480s BIOS for model 20L8. I want to delete supervisor password.
    Currently I have N22ET56W (1.33) and firmware 11.8.65.3590.
    Can you help me? Is it safe to flash and are all data (serial no, etc.) preserved?
    Also, after flash, can I safely update the BIOS?
    Thank you!
    can not, you need know Programming EC MEC..
  4. 5umi
    5umi New Member
    Ok, thanks! Do you have some documentation so I can progam it myself? If not, what are the other possibilities?
  6. 5umi
    5umi New Member
    Ok, so can I do it with this pack? Does this work for my T480s?
    You must also see your technique, I only provide a solution, can not check directly. We have tested many models
  8. 5umi
    5umi New Member
    Ok! Will search for technique documentation, than come back for the pack to do it. Thanks!
  9. pinkfreud
    pinkfreud New Member
    So, what happened? Did you find the documentation?
    I am searching for the same thing in the hopes of unlocking my t480s
