Laptop HP BIOS
Discussion in 'BIOS/UEFI' started by technical, Jul 16, 2015.
    yes, right
  2. DORINC
    DORINC New Member
    Ok. I made the payment.
    yes, you have backup bios old error send i help build fast.
  4. DORINC
    DORINC New Member
    I have USB Bios Recovery done before installing F.30 Rev.A and Backup from the face on the board that has 1mb
    Does it help you?
    How do I send?
    you use tool Recovery ? you have tool and know Programming BIOS ?
  6. DORINC
    DORINC New Member
    Attached motherboard and Bios chip model
  8. DORINC
    DORINC New Member
    Yes. I have the BIOS chip programming tool, but it does not start at the moment. Press the power button and stops in 1 sec.
    you use tool what ?
  10. DORINC
    DORINC New Member
    Hi again,
    my programming tool is with ch341 and work with 25 series flash.
    I download the your file but this *.bin is the same as the *.bin that blocked my mainboard (I used hp 083BBF30.exe).
    If you lock to "upload_org.bin" this file have 1mb not 8mb !!
    So in this moment I changed the chip from mainboard from 25q80 (1mb) to 25q64 (8mb). I flashing files with 8mb size from hp bios update but not work.
    So I wanted the 1mb bios for 25q80 chip ....
    Sorry....
    1mb no data you can skip not need Programming
  12. DORINC
    DORINC New Member
    Please tell me if it still has the chip on the motherboard because I only found one of 1MB.
    I do not have 8MB
    DA0X35MBACO Rev. C
    have, you need remove motherboard and all sticker.
  14. DORINC
    DORINC New Member
    I took down the chip on the motherboard
  15. DORINC
    DORINC New Member
    It has 1mb attached size
    These are other components that are not the main BIOS, I was surprised you did not identify this issue.
    Need to redefine whether you are a hardware technician?
  17. DORINC
    DORINC New Member
    Nu sunt tehnician Hardware,
    Acesta e singurul cip pe care l-am identificat. Te rog spune-mi unde gasesc cipul principal.
  18. DORINC
    DORINC New Member
    I am not a hardware technician,
    This is the only chip we've identified. Please tell me where I find the main chip.
    and take photo full motherboard HD i help find
  20. 08ifix
    08ifix Moderator
    need bios ULTRABOOK 13 MOTHERBOARD PART NO- G42002-200
Similar Threads - Laptop BIOS Forum Date
Yoga S730-13IWL Laptop (Lenovo) BIOS BIOS/UEFI May 28, 2019
Dell Vostro V13 Laptop BIOS Bin BIOS/UEFI Nov 16, 2018
ASUS Laptop X556UV BIOS BIOS/UEFI Aug 31, 2018
U41-70 Laptop (Lenovo) BIOS BIOS/UEFI Aug 30, 2018
