HP ProBook 640 G2 CIRCUS-6050A2723701-MB-A02
Discussion in 'BIOS/UEFI' started by technical, Aug 18, 2016.
  1. Lenzy61
    Lenzy61 New Member
    It has been dificult attaching my locked bin file. I can not see where to send it
  3. Lenzy61
    Lenzy61 New Member
    Please send a clear me bios for hp probook 640 g2. password locked
  5. vladzio
    vladzio Well-Known Member
    I bought tools to remove the password, but the revision message has no serial numbers. Laptop HP650 g1. Why the problem?
    It will automatically recover after a while of restarting. You have it wait check ?
  7. vladzio
    Yes, but serial numbers are not tightening:(
    send the bios file check i do you do it as instructed, and photo..
    inbox here i check
    Conversations 0
  9. vladzio
    all ok, make video display no serial i check.
  11. vladzio
    video display
    Is this not the original bios of the machine?
    you can returm old have password and check ?
  13. vladzio
    the original bios so, the password is not forgotten
    i think you unlock not right bios origin.
    try it.
  15. vladzio
    this works thank you! I will deal with my dump
    technical likes this.
  16. b4tech
    b4tech Well-Known Member
    HP G640 G2
    clean me
    power on no display
    fan over rpm
  18. Ninton
    Ninton New Member
    sir please make a fresh bios
    here is file bios error, you need Programming one bios new or check tool backup for you.
  20. Ninton
    Ninton New Member
    sir please make a fresh bios this bios is in restating issue
Similar Threads - ProBook CIRCUS 6050A2723701 Forum Date
Hp Probook 640 g2 Circus 6050a2733701-mb-a02 BIOS/UEFI Nov 26, 2018
HP PROBOOK 450 G3 (QUANTA X63C DAX63CMB6C0 R1A) PDF Schematics Aug 6, 2023
HP Probook 450 G3 Quanta X63 boardview Schematics Aug 6, 2023
HP ProBook 640 G4 6050A2930101-MB-A01 (A1) BIOS/UEFI Jun 26, 2019
HP PROBOOK 450 G6 DAX8JMB16E0 BIOS X8J BIOS/UEFI May 30, 2019
