HP Notebook - 15-ay005tx bdl50 LA-D703P BIOS
Discussion in 'BIOS/UEFI' started by technical, Nov 28, 2016.
  2. NUVOTON
    NUVOTON New Member
    hola puedes ayudar placa BDL50 LA-D704P quiero grabar KB9022Q PIN del teclado 32 no tengo configuración
  3. NUVOTON
    NUVOTON New Member
    ayuda por favor quiero grabar KB9022Q en mi grabador no aparece en la lista el modelo de placa
    this is problem tool, You can use the power cord to connect manually...
  5. NUVOTON
    NUVOTON New Member
    [QUOTE = "ThienBui, post: 112174, miembro: 6"] esta es una herramienta problemática. Se puede usar el cable de alimentación para completar manualmente ... [/ QUOTE]
    Alguna herramienta que pueda recomendar para tener un mejor rendimiento...
  6. mbc1968
    mbc1968 Well-Known Member
    Hi. My OLD BIOS too late to boot windows and running in "manufacture programming mode is in unlock mode"
    Could you repair my BIOS?
    old can not have error this, bios you send not origin ?
  8. mbc1968
    No. Is one of the 4 of your files: 081EF.zip
    This BIOS too late to boot windows
    this error "manufacture programming mode is in unlock mode" no problem. I can solve it
    But need clear me please.
    use bios update this
    https://vinafix.com/threads/hp-notebook-15-ay005tx-bdl50-la-d703p-la-d704p-bios.26354/
    HP Notebook - 15-ay005tx bdl50 LA-D703P BIOS BID la-d703p 081EF DMI and unlocks manufacturer test ok.bin ECROM.bin 081EF Schematic Compal LA-D703P BDL50 R1.0
    vinafix.com
  10. laptoprep123
    laptoprep123 Well-Known Member
    Hi
    Need Bios La-704p Rev 1.0 Pl help
  11. 10ifix
    10ifix Moderator
    BDL50 LA-D703P
    Rev:3.0
    model.15-ay049ne bios plz
Similar Threads - Notebook ay005tx bdl50 Forum Date
HP-Compaq HP Classmate Notebook BIOS/UEFI Jun 27, 2019
HP Notebook - 17-y018ca Diner 1.0 15285-1 BIOS/UEFI May 31, 2019
unlock pass notebook L133 BIOS/UEFI Mar 15, 2019
Xiaomi Mi Notebook Pro 15.6, Intel Core i5, GTX 1050 Max-Q 4GB 181501-AD BIOS/UEFI Mar 5, 2019
HP 348 G4 Notebook BIOS MI-6050A2811101-MB-A01 7th BIOS/UEFI Feb 23, 2019
