HP-Compaq HP G62-450ER DAAX1JMB8C0 mb
Discussion in 'BIOS/UEFI' started by technical, Feb 22, 2014.
  1. 03ifix
    sir whats next steps?
    change motherboard new :mdr: (mdr)
    check fan and power fan....
    03ifix likes this.
  3. 03ifix
    only problem is change dis to uma you send me file proper work but nothing convert intel if i remove the chip the display not come the owner laptop fight me.
  4. Santuli
    Santuli Well-Known Member
    Hi, please you havethe ec bios of AX1J board??? and maybe the clear_me too? it is UMA with the cpu soldered intel first generation. thank you
    above Available
  6. 23ifix
    23ifix Moderator
    her
    here's a 100% working file , i've got the same messages with the files above , this file worked very well
    • g62.bin
      File size:
      4 MB
      14
  7. jopp85
    jopp85 Well-Known Member
    Ho avuto lo stesso problema di ventola al massimo e spegnimento con thermal error. Ho risolto con reballing gpu ma adesso anche dopo aver installato sistema operativo e driver la ventola gira sempre veloce anche se con speccy leggo 26° cpu ma 78° mother board temperature. Devo riscrivere un clear me oppure può essere bd difettoso?
    send i file bios this you.
  9. jopp85
    ecco il file originale e quello che fa quel problema di temperatura
    try this
  11. jopp85
    thank you very much, with this file all ok motherboard temperature is only 30°.
Similar Threads - 450ER DAAX1JMB8C0 Forum Date
HP-Compaq HP G42 - DAAX1JMB8C0 - INTEL Schematics Mar 12, 2014
