HP EliteBook 840 G3 6050A2892401-MB-A01
Discussion in 'BIOS/UEFI' started by technical, Feb 26, 2017.
  1. maraketh32
    maraketh32 Well-Known Member
    can anyone remove password from this file?
    unlockssss.bin
  3. maraketh32
    thank you. i will test it in a few minutes!
  4. maraketh32
    it works! thank you very much!
  5. sivanov
    sivanov Well-Known Member
    Hi admin, i have the problem with "this device belongs to...". I change 8 and 16mb bioses and clear me region. Laptop works fine when install the windows and message not come again, but after 3-4 restarts start to blinking caps lock and make sound 3 long 2 short times and no display. I think this is not the right bios from first post, i check that the region of the old one and the new is not the same. Any ideas what to do?
    It is very difficult to judge directly and test all components
  7. sivanov
    may be bios that upload in first post is for DIS, my board is UMA.
    try it and you need check hardware, Discrete or uma no is problem bios.
  9. maraketh32
    so it seems that desoldering leads to many issues. i followed a circuit straight to the cpu that was intrerupted. both my laptops are ok now. thank you ThienBui for your support
    technical likes this.
  10. Touseef Khan
    Touseef Khan Well-Known Member
    i check 6050A2892401-MB-A01 bios above not working this is my backup file but it is locked by password plz clear password for me or also upload clear me bios working file
  11. Touseef Khan
    i flash your bios but no display this is my working backup but locked by pass
    unpass.bin
  13. sivanov
    Okay, we found the problem. Its in ram. We changed the ram and everything is fine now. No white screen, no problems.
  14. Touseef Khan
    thanxx this bios is working
  15. shakeel
    shakeel Well-Known Member
    Sir HP EliteBook 840 G3 6050A2892401 bios password pls clean this
    unpas.bin
  17. meuva umar
    meuva umar Well-Known Member
    I NEED hp 6050A2892401-MB-A01 CLEARME BIOS
  19. levi
    levi Well-Known Member
    admin, pls i purchased this tutorial but my bios bin seems totally different from the sample in this tutorial. can help unlock my bios for me? later on i ll follow the tutorial
  20. Marcos Borges
    Marcos Borges New Member
    Could you remove the password from this file, please?
Similar Threads - EliteBook 6050A2892401 Forum Date
HP EliteBook 850 G3 6050A2892401-MB-A01 BIOS/UEFI Dec 31, 2018
hp elitebook 840 g5 BIOS/UEFI Feb 3, 2021
HP EliteBook 745 G6 BIOS/UEFI Aug 1, 2019
HP EliteBook 755 G5 TRYPTICO 6050A2945701-MB-A01 (A1) BIOS/UEFI Aug 1, 2019
HP EliteBook 1050 G1 BIOS BIOS/UEFI Jun 28, 2019
