HP EliteBook 840 G2 Notebook - BIOS
Discussion in 'BIOS/UEFI' started by technical, Aug 1, 2015.
  1. nhan
    nhan Well-Known Member
    giúp e xóa pass con này với ad
  2. nhan
    nho ad xoa pass file nay dum em
  3. Rodolfo Felix
    Rodolfo Felix Well-Known Member
    Tengo los archivos del 840 G2 pero tienen Password se puede eliminar de estos archivos o cuales de las bios es la que ocupo si el modelo de la placa es 6050A2637901 - MB - A02 CHICLET
  4. Eugen
    Eugen New Member
    Hello Admin,
    can you remove the password from the file?
  5. matrixms
    matrixms New Member
    Sorry, but I have to post all story, cause I have multiple problem.
    First, I have elitebook 840 g2 without bios chip (removed from motherboard). So, I don't have original locked bios.
    Second, I bought few new (7-8) winbond 25q128fv chips in two stores and I have ch341 black programmer. Every single chip I bought had already some lines written on them ( I don't now how to explain, but you will understand). I can not full erase chip, do I have to do it at all?? I find a tons of bios files but not the single one can verify! All of them - 'chip main memory with the content are in disagreement' or something like that.
    Even this one you posted above.
    I never had that problem with any other chip. I do not know what I'm doing wrong.
    can you help me, please? It's urgent, and I'm desperate
    #27 matrixms, Jun 12, 2018
    That means you can not program the BIOS ?
  7. matrixms
    matrixms New Member
    I write bios file, but when verify - 'chip main memory with the content are in disagreement'. Every single time with every chip I got ( 8 of them- new from two markets). And none of them was completely empty when I bought them, on first reading. I don't know if it's normal or not.
    It never happened to me before, with other chips.
    So, I do not know does winbond 25q128fv suposed to be fully empty and how to do it? Why every bin file I write on it - can't verify? Could you help me, please?
    I can not help, you need to check the connection, check the chip, check the programming tool.....
    Note: The BIOS file can not be faulted as above.
  9. matrixms
    matrixms New Member
    Ok, sorry. I will buy another pack of chips. And another programmer.
    Could you tell me how to know which bios file is real one for hp elitebook 840g2 6050A2637901-MB-A02? How to be sure which is right one to my laptop, considering I do not have original locked bios? And, considering I have 'another bios' 'small bios' or 'ec bios' i don't now how you call it, should I have both bios files to be 'paired' ?
    Only check motherboard code and downloads BIOS same code and Programming.
  11. QuocKhanhLaptop
    QuocKhanhLaptop Well-Known Member
    840 G2 Unpasss.BIN
  13. ikapitale
    ikapitale New Member
    plz unlock password bios from this file
  15. ikapitale
    thanks very much
  16. ikapitale
    plz unlock password bios from this file with thank's
  18. ikapitale
    thank's very much Thienbui
Similar Threads - EliteBook Notebook BIOS Forum Date
HP-Compaq clear me please HP EliteBook 820 G3 Notebook 6050A2725001-MB-A01 BIOS/UEFI May 6, 2017
HP EliteBook 848 G3 Notebook PC BIOS/UEFI Aug 29, 2016
HP EliteBook 820 G3 Notebook 6050A2725001-MB-A01 BIOS/UEFI Aug 29, 2016
HP EliteBook 755 G3 Notebook BIOS/UEFI Aug 29, 2016
HP EliteBook 725 G3 Notebook 6050a2725101-mb-a01 BIOS/UEFI Aug 29, 2016
