HP-Compaq HP EliteBook 820 G1 BIOS
Discussion in 'BIOS/UEFI' started by technical, Sep 3, 2015.
  1. intancomp
    intancomp New Member
  2. cikez
    cikez Well-Known Member
    Hi!
    Can you unlock my bios please?
  4. cikez
    Sorry, but it isn't working. Laptop restarts and behaves wrong.
  5. 01ifix
    here your file unlocked try it and post results
  6. cikez
    It behaves same way, on every bios, even on my old one now:
    -Ramping fans immediately after pluging ac adapter or battery,
    -When you push on/off button it starts to boot, hp logo shows and then laptops turns off with strange noise from speakers and blinking backlit keyboard.
    bios old you send have problem, returm old and check send one photo or video display request password.
  8. cikez
    Old bios:
    -After pluging AC adapter fans ramping immediately (and LED is turned on, but computer isn't booting),
    -Password request
    check all ok, sure only passsword ?
  10. cikez
    Well, I worked on it for a few days and really don't know what is going on. Before everything, Laptop was working just fine. I realized that bios have password on it. I tried different bios from this forum and from that time laptop is completly broken. No matter what bios I install (even the same bios from begining) when you connect battery or ac adapter, and not clicking power, it just ramp up fan. I took bios chip and solder it to another (the same) laptop, and it works almost okey. I think that after all it isn't BIOS fault, I just gave up. I will try to fix it (and if I do fix), I will post my fix here.
  11. Kapitan Bomba
    Kapitan Bomba New Member
    Hi,
    can I ask for unlocking the BIOS?
    unpassss.bin
  13. Kapitan Bomba
    It works perfect. Thank you ThienBui, you're reliable man.
  14. khongminh
    khongminh Well-Known Member
    admin clear me dùm bios này fix luôn báo machine is not in committed state
  16. khongminh
    hi admin ! unlock pass dùm file này, file clear trên vẫn chậm lắm
    gửi 1 hình password bios this
  18. EnriCo21
    EnriCo21 New Member
    I can remove, but send bios dump to filehosting.
  19. 01ifix
    try it
  20. ipodnano16g
    ipodnano16g Well-Known Member
    Admin nhờ anh xóa pass giùm e
Similar Threads - EliteBook BIOS Forum Date
HP EliteBook 1050 G1 BIOS BIOS/UEFI Jun 28, 2019
HP EliteBook x360 1040 G6 BIOS BIOS/UEFI Jun 28, 2019
HP EliteBook x360 1040 G5 BIOS BIOS/UEFI Jun 28, 2019
HP-Compaq i need unlock bios hp elitebook 840 G3 BIOS/UEFI Apr 30, 2019
Xin bios HP Elitebook 1040 G4 mã main DA0Y0UMBAD0 BIOS/UEFI Mar 12, 2019
