HP-Compaq HP 15-d035dx OSAMU2_BT_HPC MV_MB_V1
Discussion in 'BIOS/UEFI' started by 15ifix, Mar 14, 2014.
  1. brixlaptop
    brixlaptop Well-Known Member
    hi sir you fix it?
  2. brixlaptop
    ok i find..help me also hp-14-d017au thanks
  4. eltunisie
    eltunisie New Member
  5. 02ifix
    02ifix Well-Known Member
    i there , i got the tl866cs flasher , and just upgraded to V.6.50 and flahsed firmware . i got the 1.8 adapter that i bought on ebay , now i added the adapter to the flasher and inserted the 64FW rom chip , but i still can't read it or detect it . is there something that im doing wrong ?
    btw the jumper i put it on the 1.8 selector , there are 2 options , 1.8 v or 2.5 , so i leave jumper on 1.8v
      File size:
      58.4 KB
      6
  6. 02ifix
    well not working on tl866 programmer this adapter , for the tl866 its needed the SN006_25_1.8V
  7. Arun
    Arun Well-Known Member
    ec bios
  8. 02ifix
    your bios is pratically empty kkk you only have one hex string . all the rest is 00000
  9. laptoprep123
    laptoprep123 Well-Known Member
    need schematic pl QSAMU2_BT_HPC
    HP 15-d088sr
  11. Anand salunke
    Anand salunke Well-Known Member
    Hi,
    looking for BIOS for HP 15-d008tu. EC BIOS 512K and Main BIOS 8 M - clear ME. Pl help.
  13. 09ifix
    09ifix Moderator
    osamu2-dis_kb is it 4mb bios or 8mb???
    8MB.
    HP 14-d041tu
    BIOS 0218B
  16. chaminda2018
    chaminda2018 New Member
    its not working. the board was worked before accidentally erase the bios from me.The Board P/N is 010194Q00-491-G HP P/N 747139-001. please gv asap.thanks
    Screen Shot 2016-10-19 at 12.08.47 PM.
    correct code ?
  18. chaminda2018
    see the photo
  19. chaminda2018
    motherboard photo i have send you. the correct laptop model is 15-d041tu
    BIOS is 8MB
    are you sure the machine you use 8MB or 4MB ?
    there may have been someone to repair or replace the incorrect.
    needs more testing.
    All the above is good bios
Similar Threads - d035dx OSAMU2_BT_HPC MV_MB_V1 Forum Date
HP-Compaq HP 15-d035dx OSAMU2_CR_HPC MV_MB_V1 BIOS/UEFI Jan 15, 2015
