HP 15-ba036ur - la-d711p
Discussion in 'BIOS/UEFI' started by technical, Aug 27, 2016.
  1. amrish
    amrish Well-Known Member
    pu601 icno.BAASZA
    Here is what ?
  3. tanveerah2005
    tanveerah2005 Well-Known Member
    la-d711p CLEAR ME REAGIN THANKS
    Here is AMD no have Me Region :p
  5. 02ifix
    02ifix Well-Known Member
    la-711p rev3.0 bios if possible !
    same version above.
  7. 02ifix
    i don't know why you say revision 1 work on revision 3 , since it won't work !!! tryed it at fast fan and black screen all the time and shity consumption 0.40 amp .
    here it is a WORKING bios for REVISION 3.0
    insyde you have the 4 different BID for this equipment ,
    BID081F5 is the bid of you bios for revision 1.0 and also the same bid as my original bios , and it only worked with the bios im uploading now , for revision 3.0
    Higher Functions and gmedia like this.
    yes, you check same BID old BIOS for you..
  9. 02ifix
    KKK YOU didn't understand eheheh , nevermind !! :p
  10. tanveerah2005
    bdl51 la-d711p rev 1.0 bios
    BID081F5 F09
    NEED THIS BIOS FOR HP 15 AMD Processor or fix this bios
    Thanks !
    BIOS Available on top how ?
  12. soumen saha
    soumen saha Well-Known Member
    la-d711p ec pin configuration plz
  13. soumen saha
    la-c701p or la-c811p...pin configuration will match??
  14. lifestone
    lifestone Well-Known Member
    i need HP 15-ba036ur - la-d711p
    BIOS BID082F6
    082F6.bin
  16. bhavneet singh
    bhavneet singh Well-Known Member
    la-d711p rev 3.0
  17. bhavneet singh
    i have an original bios of this product
    it was showing display.
    In this case you can send me a new biios it was not showing display
    bios old have display error what ?
