HP 15-ay001nx - BDL50 LA-D702P BIOS Schematics
Discussion in 'BIOS/UEFI' started by technical, Feb 18, 2017.
  1. singhcomputer
    singhcomputer Well-Known Member
    NEED BDL50 LA-D702P REV : 3 .0 MAIN BIOS & EC BIOS
    on top Available, Please provided info old bios and laptop error what where try bios above but not work ?
  3. singhcomputer
    hp 250 g5 EC PLZ
    motherboard code ?
  5. singhcomputer
    BDL50 LA-D702P BIOS REV : 3.0 (HP 250 G5)
    You asked many times I want to know the laptop and bios old error what????
  7. digitalw
    digitalw Well-Known Member
    hi my friend
    do you have schematic BDL50 LA-702P? if you have it, would you mind sharing it
    current Unavailable
  9. digitalw
    ok thank yuo
  10. sudarsanankumar
    sudarsanankumar Well-Known Member
    Unavailable schematic
  12. sudarsanankumar
    power on , led ok , dc power supplay .01 amp is taken ,
    adaptor connect there is no volt in 3&5 coil , power on , its come , but no s4 signal ,
    pls help me
    It is difficult to test hardware over the network.
    try one BIOS new before ?
  14. cp9laptop
    cp9laptop Well-Known Member
    i^ ok
    dòng này ko có fan mà bị báo lỗi fan 90B admin và các bác có giải pháp nào ko???
    những gì đã thay đổi hoặc sửa chữa bạn ?
  16. cp9laptop
    ngon rồi bác,đánh rửa có chút gỉ sấy lại main đc luôn- có lẽ trở báo quá nhiệt- ko có sche ko tra đc
  17. MissAircraft
    MissAircraft SUPER VIP
    Hi, can somebody identify that IC? its 3.3v/5v regulator
    RT8243AZQW
  19. jOSUEJJJJ
    jOSUEJJJJ New Member
    HELLO
    DO YOU HAVE APPLICATION DMI FOR BDL50 LA-D702P REV 3.0 2016-06-15
    THANK'S
    you ask tool fix DMI ?
    This model needs manual repair.
Similar Threads - ay001nx BDL50 D702P Forum Date
HP-Compaq e đang cần shematic BDL50 LA-D703P rev 1.0 Schematics Jul 20, 2019
hp-15-bd003tx-BDL50 la-d704p Rev 4.0 BIOS/UEFI Nov 17, 2017
HP Notebook - 15-ay005tx bdl50 LA-D703P BIOS BIOS/UEFI Nov 28, 2016
