Disable RAM onboard Asus x550cc
Discussion in 'Computer Hardware Repair' started by technical, Aug 30, 2016.
  2. Franklim Miranda
    Franklim Miranda Well-Known Member
    actually this issue is not caused due to RAM, but due to the processor trust me, i'v never come across such a thing and find out latter on the it was due to RAM issues, but always due to Processor, and as you know unfortunate you processor is soldered to the board (BGA) so is not going to be very fan to fix it.
    technical likes this.
  3. 06ifix
    06ifix Moderator
    Gia hạn VIP đi chứ ? :mdr: (mdr)
  5. 06ifix
    06ifix Moderator
    ngan hang chua giai ngan :nrg: ,neu kip chieu nay moi gia hang .ma co khong su huynh
  6. Elect_T
    Elect_T New Member
    Hi, I've also followed the steps of this tutorial but in my case the problem was that the onboard RAM its faulty and shows errors at memtest86+ and also using the laptop. After shifting the place of the 3 resistors at the X550CC Rev 2.0 motherboard the problem still happens because the onboard memory is still detected.
    Is there any other modification that is needed to be done?
    Regards.
  7. AmaSua
    AmaSua Well-Known Member
    DISABLE RAM ASUS X550EP?
  8. bigphong
    bigphong Well-Known Member
    You Have Disable Onboard RAM Asus X450CC REV 2.1 ?
  9. k420
    k420 New Member
    Have move the 3 resistors sill detects onboard ram
  10. k420
    k420 New Member
    Asus x550cc rev 2.0
    how? detail problem
  12. k420
    k420 New Member
    This pc have ram issues, but powers on to bios .
    Have moved the 3 resistors stil detects the 4gb onboard
    I what to deactivate the onboard ram to tuse only the slot, i have done on similar model whis vinafix documentation and whas on first try.
    do you mean ram disable failed?
  14. k420
    k420 New Member
    yes
    failed
    failed how? i ask but you not show any problem failed...
  16. k420
    k420 New Member
    Failed becuse i have moved the resistors and still dectects the ram . do i have to probram bios ?
    no Programming bios, send photo location move i check.
    Note: Please clear the converted resistors I do not ask many times without a clear view
  18. k420
    k420 New Member
    WhatsApp Image 2019-06-26 at 11.53.19. WhatsApp Image 2019-06-26 at 11.54.15.
Similar Threads - Disable onboard Asus Forum Date
UNABLE TO DISABLE ONBOARD RAM ASUS Computer Hardware Repair Aug 20, 2017
Asus K50IJ rev 2.1 - how to disable onboard memory? Computer Hardware Repair Mar 25, 2017
Disable RAM onboard Asus S301LA r2.0 r2.2 Computer Hardware Repair Nov 11, 2016
Disable RAM onboard Asus X552W X550WE REV 2.0 Computer Hardware Repair Nov 9, 2016
Disable RAM onboard Asus X751MD r1.1 r2.0 Computer Hardware Repair Nov 8, 2016
