Dell Dell inspiron 15-3542 13269 FX3MC
Discussion in 'BIOS/UEFI' started by technical, Mar 2, 2015.
  1. laptech
    laptech Well-Known Member
    1 . dell 3542 laptop 4 Beep but Ram voltage is OK
    2. plz send me boardView
    think you
    Unavailable boardview this.
  3. KimComputerLX
    KimComputerLX Well-Known Member
  5. asmshoab
    asmshoab Well-Known Member
    HP Probook 4441s bios need
  7. lightsky
    lightsky Well-Known Member
    ad clear me giúp mình với . dell 15 3543
  9. zmogienas
    zmogienas Well-Known Member
    Solved 4 beeps problem? I have the same.
  10. laptech
    Yes i solved 4 beep problem Ram socket change socket pin is brokin
  11. hgzy ahmd
    hgzy ahmd Well-Known Member
    FX3MC REV.A00. HI MY FRIENDS
    IN ATTACHMENT OLD BIOS FOR DELL
    CEDAR_INTEL-MB 13269-1 PWB. FX3MC REV.A00
    THIS BIOS WORKING FAN SPINNING CPU AND GPU HEATING NO AUDIABILE BEEPS
    I TRIED ALL ABOVE ROMS ALL NOT WORKING
    2 BEEPS
    CPU AND GPU NOT WORMMING
    PLEASE I WANT THE SAME VERSION
    THANKS FOR ALL
    FX3MC REV.A00.
    The above BIOS has a lot of I can not help any more. You need downloads and Programming above.
  13. laptoptpt
    laptoptpt Well-Known Member
    xin bios con này: Mã máy Dell Inspiron 3870. mã mainboard: CEDAR_INTEL-MB 13269-1 FX3MC REV A00 , chạy i5 5200U.
    file bios lưu đang chạy model 3543 A08, không nhận ổ cứnd và ổ Đĩa
    #73 laptoptpt, Jan 17, 2018
    Dinusha likes this.
  14. laptoptpt
    kkk dùng con bios khác chép lại file trên thì nhận dc hết rồi, nhưng có model 3870 thì cho xin nạp lại cho trùng với máy
  15. laptech
    Dell inspiron 15-3542 13269 FX3MC VB
  16. sherifbekhit
    sherifbekhit Well-Known Member
    Hi dear
    after charging the bios I found problem ..what is't ?
    when remove the TRC machine go work , when recover the TRC machine not work
    why ??
    can help me
    thanks
  17. 03ifix
    You means cmos battery (TRC).
  18. sherifbekhit
    yes dear
  19. 03ifix
    If this bios same not bios problem.
    sherifbekhit likes this.
  20. sherifbekhit
    Thank you sire
Similar Threads - Dell inspiron 3542 Forum Date
Dell Inspiron 15-3542 - 13269-1 FX3MC Schematics Jun 10, 2016
Dell Inspiron 7586 2-in-1 BIOS 18706-1 BIOS/UEFI Jul 12, 2019
I Need schematic of Dell Inspiron 13 2in1 7373 Schematics Jun 6, 2019
Dell Inspiron 3180/3185 BIOS Rocket 11 MLK AMD 17876-1 BIOS/UEFI Apr 27, 2019
Dell Inspiron 13 7386 2-in-1 BIOS/UEFI Apr 9, 2019
