DELL E7470 bios
Discussion in 'BIOS/UEFI' started by JackT, Apr 21, 2017.
DELL E7470 bios 5 5 1votes
  1. JackT
    JackT Well-Known Member
    Hi ,
    i recently got a dell E7470 . its working but bios admin is locked by code. I removed the bios chip W25Q128FV and flashed one of the bins available here but the laptop is turning on but not booting.
    I am uploading the original bin file read from the chip. Can anyone remove the code from the original bios or have any other ideas?
    Thanks in advance! :)
    the board is AAZ60-LA-C461P and the code i get is FV1CFC2-6FF1
    Similar Threads - DELL E7470 bios Forum Date
    E7470 Dell Bios bin file LA-C461P BIOS/UEFI Apr 28, 2017
    BIOS bin file for Dell E7470 LA-C461P BIOS/UEFI Apr 26, 2017
    Dell Latitude E7270 and Latitude E7470 BIOS AAZ50 LA-C451P Latitude Dec 10, 2016
    Bios Dell Latitude E7470 LA-C461P-intel 6th(Gen) BIOS/UEFI Nov 27, 2016
    Clear ME Dell E7270 and E7470 Latitude Mar 2, 2019
    Programming bios this @JackT
  4. 21ifix
    21ifix Moderator
    pass :
    4KtszzRtfG1Mzibm
  5. JackT
    tried to enter this key but its not accepted. (i pressed enter and ctrl+enter)
    i had found the same but didnt work
  6. JackT
    thanks for the quick reply. the bios you gave is working but admin is still locked . it is booting now but i cant boot from usb device.
  7. JackT
    managed to unlock it by code generator with this code:
    t - tango ( lowercase )
    V - VICTOR ( UPPERCASE )
    b - bravo ( lowercase )
    0 - ( digit )
    w - whisky ( lowercase )
    E - ECHO ( UPPERCASE )
    F - FOXTROT ( UPPERCASE )
    H - HOTEL ( UPPERCASE )
    f - foxtrot ( lowercase )
    D - DELTA ( UPPERCASE )
    Q - QUEBEC ( UPPERCASE )
    3 - ( digit )
    Thank you all for the help!!!
  8. niggar
    niggar Well-Known Member
    clear me please motherboard is LA-C461P VER 0.4 I BUY 11. COLLECTION BUT IT WON'T HELP FOR THIS CHIPSET IS 129.24 .PROBLEM DISPLAY COMES LATE AS LIKE 1 MINUTE
    Model this you can use 11.0.0.1197
  10. niggar
    NO 11.0.0.1109
    I know but you can use 11.0.0.1197 instead
  12. niggar
    I ALREADY TRY ALL BIOS ALSO TRY THIS BUT PROBLEM IS 130.52 YOU CAN SEE THE PICTURE ATTACHED IN LAST POST CHIP IN IS 129.24 NOT 130.52
    you Understand how is 130.52 and 129.24 ?
    Can explain why you are interested in this place.
  14. niggar
    BECAUSE CHIPSET IS DIFFERENT WHEN YOU CLEAR ME FOR H SERIES IT SHOWN 147.
    It same LP series not H Series,
    Me Region is a software that can update the version.
    We can not help you when you have a look that is not like us. You can manually solve this problem or use a new BIOS.
  16. niggar
    HMMMMMMMMMMMMMM :(:(:(:(:(:(:(:(:(:(
    #15 niggar, May 26, 2018
  17. niggar
    CAN YOU FIND FOR ME 11.0.0.1100 5MB ME REGION
  18. Arif Wahedi
    Arif Wahedi New Member
    ThienBui Sir
    This Computer DELL E7470 Bios is Heing up on Dell Logo
    Please Check It . Or Send Me Compitable Link To Program New One
