Dell Dell e5540 PLYTA LA-A101P REV:1.0
Discussion in 'BIOS/UEFI' started by technical, Jun 23, 2015.
    not problem Me Region you need check hardware.
  2. dan1200rr
    dan1200rr Well-Known Member
    Yes, I noticed that after some time - I fixed it with this Clean ME Bios this is NOT a Hardware Problem! Cheers.
  3. kashyapdarania
    kashyapdarania New Member
    but it shutdown exact after 30 min.
    then if start again then after 30 min its power off
  4. dan1200rr
    Check my last Bios, I fixed the shut down problem, in Bios registry was "ASF2 Force off". Now runs without problems
    you can use one BIOS new but not problem Me Region.
  6. kashyapdarania
    ok i will check.
  7. kashyapdarania
    i try your new bios but same issue, power off after 30 min.
    yes, check hardware.
  9. kashyapdarania
    its not hardware issue.
    if its hardware problem then its not power off exact 30 minute.its randomly off.
    i check not see you downloads all bios i provided, why ?
  11. kashyapdarania
    means i don't understand what u tell ?
  12. kashyapdarania
    have u any idea about ASF2 force off ?
  13. kashyapdarania
    dell e5540 la-a101p help me to clear me
    it's a late display problem
    i try with me injector to clear me nut then wifi card not detect.
    if i write old bios then all ok but only late display
    • U1.bin
      File size:
      8 MB
      26
  15. kashyapdarania
    not start in this bios
    tr file this and can send one video display late
  17. kashyapdarania
    laptop on but no display in this bios
  18. kashyapdarania
    after press power button display takes about 25 sec to come
  19. 03ifix
    Try this and post results.
  20. kashyapdarania
    sorry bro but laptop is already givesn.
    but i find solution for this type of bios 8mb+4mb bios.
    you don't update me using me injector for this type bios.you have to use fitc tool for this.
    i already done it but thanks for help.
Similar Threads - Dell e5540 PLYTA Forum Date
Dell Latitude E5540 UAW50 LA-A101P Schematics Schematics Sep 28, 2017
Schematics for VRWRC 13124-1 Dell optiplex Schematics May 2, 2023
Dell G5 5590 VULCAN17_N18P BIOS/UEFI May 1, 2020
BIOS PC Dell insprion aio 3275 BIOS AMSTR-PS REV A00 BIOS/UEFI Aug 21, 2019
