Bios Dell Latitude E7470 LA-C461P-intel 6th(Gen)
Discussion in 'BIOS/UEFI' started by 20ifix, Nov 27, 2016.
Bios Dell Latitude E7470 LA-C461P-intel 6th(Gen) 5 5 1votes
  1. 20ifix
    20ifix Moderator
    Bios Dell Latitude E7470 intel Core I-6xxx
    Motherboard model : AAZ60 - LA-C461P
    Rev: 1.0(A00)
    Similar Threads - Bios Dell Latitude Forum Date
    Dell Latitude 5580 BIOS LA-E092P BIOS/UEFI Aug 3, 2019
    Dell Latitude 5590 BIOS DM80-LA-F412P BIOS/UEFI May 18, 2019
    Dell Latitude 3189 BIOS LA-E371P BIOS/UEFI Apr 17, 2019
    Dell Latitude 7390 2in1 LA-F291P BIOS BIOS/UEFI Mar 12, 2019
    Dell Latitude 5580 Compal CDP80 LA-E151P Schematics and BIOS BIOS/UEFI Nov 30, 2018
    Dell Latitude E7470
    LA-C461p rev1(A00)
  4. laptopvn
    laptopvn Well-Known Member
    2 file trên chép không chạy, clear ME chép cũng không chạy
    2 file dưới là 2 file gốc chạy lên hình tốt, đổi chéo 2 con rom qua lại cả 2 máy đều không chạy lên hình
    Dell Latitude-E7470-LA-C461P Unpass
    Dell Latitude-E7470-LA-C461P Uncomputrace
  6. 20ifix
    20ifix Moderator
    Bác thử với file này ...đã clear computrace và tested ok !
  8. 05ifix
    05ifix Moderator
    You have any tutorial how to remove computrace for 7th gen ? thanks
    only can build one bios new. ( need have file bios old computrace and one file bios new downloads in vinafix.com we can build. )
  10. 05ifix
    05ifix Moderator
    Ok i understand, but how we can do this ? a tutorial ?
    Unavailable, When you ask I will provide ( but have fee )
  12. 20ifix
    20ifix Moderator
    Pls send computrace file to try .
  13. bushmann
    bushmann Well-Known Member
    Hi all.
    I trying flash this BIOS and notebook not start up.
    Same board version and CPU version.
    I'ts possible used other unComputrace BIOS, or must be same BIOS but must be unComputraced .
    Please help me, I have BIOS with Coputrace ON and i need off this function OFF.
    BIOS file is attachment .
    Thanks
  15. khaledmax
    khaledmax Well-Known Member
    HI THIS IS NOT CORRECT .. work but error to install drivers
  16. khaledmax
    HI THIS dump IS NOT CORRECT .. work but error to install drivers
    install drivers what?
  18. 08ifix
    08ifix Moderator
    THERE IS BIT LOCK CAN ANY ONE UNLOCK IT. ABOVE ALL BIOS I TRIED NONE OF THEM WORKING
  19. 08ifix
    08ifix Moderator
    IS IT IN HDD BIT PASSWORD??
  20. 03ifix
    Bit lock? i think bit lock is windows hard drive lock not bios.
  21. MCSCOM
    MCSCOM Well-Known Member
    Need an ec (UV9) for 7470
