ASUS Vivobook X556UV
Discussion in 'BIOS/UEFI' started by technical, Aug 22, 2016.
  1. 38ifix
    38ifix Well-Known Member
    same issue
  2. Khalidna
    Khalidna Well-Known Member
    please build the file
    build.bin
  4. Khalidna
    please make it good
    original file Fan spin
    0.956 Amps
    buil file No fan spin
    0.230 Amps
    i'm sure this bios problem
    please check error
    why need build? bios Available here
    Programming it
    ASUS VM591U X556UV I7 7th.BIN.zip
    https://vinafix.com/threads/asus-vivobook-x556uv.23853/
    ASUS Vivobook F556U X556UV CPU 6th BIOS X556UV Rev 3.1 Boardview Asus X556UV 3.1.fz ASUS X556UV-X556UJ-X556UA-X556UB-X556UF-X556UQ-X556UQK-X556UR REV3.1.pdf Processor Intel® Core™ i7 6500U...
    vinafix.com
  6. Khalidna
    why two @Appleexpert and @Luís Amaral test it work good?, only problem driver VGA
    you can read comment above.
    check hardware sure
  8. Khalidna
    this orinal file issue
  10. 02ifix
    02ifix Well-Known Member
    witch one , first or second one ?
  11. 02ifix
    so ok , i tryed first one , it gived image , started to go to system , it started t put devices ready then restarted directly to bios on EZE flash utility by itself and update from 306 to 313 version , now waiting to see if video is ok
  12. 02ifix
    yeah we got a winner :D thank thien , itn was a longlast fight today han ? :p
    this one did the trick
  13. dilippawar31
    dilippawar31 New Member
    asus x556uv board view is not open on pcb repair tool..
  14. mukesh badola
    mukesh badola Well-Known Member
    urgent need CLEAR ME X556UV_MB BIOS
  15. mukesh badola
    Urgent Need CLEAR ME BIOS X556UV REV:3.1
    file and cause want to clear me.
  17. mukesh badola
    OLD DUMP X556UV
  19. kmro16
    kmro16 New Member
    Hello.
    On laptops with Nvidia graphics, the BIOS must be compatible with the version of the graphics chip. If you have 920MX then you need to have a BIOS from the motherboard with such a graphics chip. The same applies to 930MX and 940MX in this model. This applies to many models because I have already dealt with the problem in Asus K53, X53, X550, X555, Lenovo Y50, Y70, 310-15 and many other laptops with Nvidia graphics. If you program the BIOS from a different version of the graphics chip, there will be an error in the device manager.
Similar Threads - ASUS Vivobook X556UV Forum Date
ASUS VivoBook S15 S530FA BIOS BIOS/UEFI Aug 12, 2019
ASUS VivoBook 15 X540UV BIOS/UEFI Jun 14, 2019
ASUS VivoBook Flip 15 TP510UA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 14 TP401CA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 12 TP203NAH BIOS/UEFI May 12, 2019
