ASUS Vivobook X556UV
Discussion in 'BIOS/UEFI' started by technical, Aug 22, 2016.
  1. 38ifix
    38ifix Well-Known Member
    update drivers online
    and my bios erese sir
  2. 38ifix
    my laptop
    core i5
    7th generation
    Programming it now and feeback
    i wait
  4. 38ifix
    no display
    Original bios you have save or not ?
  6. 38ifix
    check chip GPU
  8. 38ifix
    no sir
    gpu perfact
    your bios problem sir
    how you know ?
  10. 38ifix
    before it is working properly after that bios flashing nvidia driver showing yellow, but the syetem original bios file is missing
    one mr luice amaral having this same issue reported am also having this same situation
  11. 38ifix
    any solution
    no have, all bios i provided for you but same problem.
    I recommend you download the driver from the manufacturer to install. and check again GPU.
  13. 02ifix
    02ifix Well-Known Member
    unfortunetly not giving any image on the display and stasrt with a consume of 0.32 amp :|
    but @Appleexpert try and say it working only problem GPU
  15. 02ifix
    also your bios make the machine to start alone , even if you swith it off it switch on again
  16. 02ifix
    apple expert refers to the 7gen bios you have on first post , this one works but gives me the yellow triangle . we allready had this kind of issue in the past with the bios , and in the end i had a old original that i could fix , but for this board i only got the suposed original file that come with the board . unfrotunely we are a laboratory that works with stores from north to south of portugal , so many machines sometimes can come with previous fixes . so chek that out please really need this bios working
  17. pampanga chapter
    pampanga chapter Well-Known Member
    Can you clear ME for me? thanks good speed...
  18. 38ifix
    already original file is missing do you have any files?
  19. 02ifix
    do you have any issue in hopening a new thread requesting your clear me ??? this bios as nothing to do for this model , don't be lazy !
  20. 02ifix
    my machine has
    ntel® Core™ i7 6500U Processor,
    • NVIDIA GeForce 930MX
Similar Threads - ASUS Vivobook X556UV Forum Date
ASUS VivoBook S15 S530FA BIOS BIOS/UEFI Aug 12, 2019
ASUS VivoBook 15 X540UV BIOS/UEFI Jun 14, 2019
ASUS VivoBook Flip 15 TP510UA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 14 TP401CA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 12 TP203NAH BIOS/UEFI May 12, 2019
