ASUS Vivobook X556UV
Discussion in 'BIOS/UEFI' started by technical, Aug 22, 2016.
    provided right code above motherboard
  2. 38ifix
    38ifix Well-Known Member
    x556uv mb-rev.3.1
  3. tianno
    tianno New Member
    Please remove the password from this file.
    need Programming one bios new
  6. tianno
    tianno New Member
    You would have the new x556uv rev 3.1 i5 7200u
  7. 02ifix
    02ifix Well-Known Member
    on this one i used the
    ASUS VM591U X556UV I7 7th.BIN.zip and this file work ok , but gpu have yellow triangule (controler error)
    this guy bios computer give image , it takes sometime to display image , but it requires bios admin password to carry further to see if this bios displayed well the gpu , so once again , can you help me out ?
    also clear me of post #74 does turn on with good consume but no image !
    asus k556UR
    board x556uv 3.1
    intel i7 7gen cpu
    discrete gpu
    old bios error what? send i check
  9. 02ifix
    my old bios , start with 0.27 amps of consume and no display and no cpu phases runing . tryed with LBE fixing with the version on the site but same issue . anyway here it is .
    try it
  11. 38ifix
    your file working but nvidia grapice note working sir
    any others file you have
    not working how send one photo problem i check
  13. 38ifix
    intel gpapice working but nvidia gpapice driver yellow sir
    any solution
    i need see photo or video
  15. 38ifix
  17. 38ifix
  18. 38ifix
    laptop format and restall driver everthing
    but nvidia note control sir
    driver you downloads where? send link i check.
    and send i file bios Original.
Similar Threads - ASUS Vivobook X556UV Forum Date
ASUS VivoBook S15 S530FA BIOS BIOS/UEFI Aug 12, 2019
ASUS VivoBook 15 X540UV BIOS/UEFI Jun 14, 2019
ASUS VivoBook Flip 15 TP510UA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 14 TP401CA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 12 TP203NAH BIOS/UEFI May 12, 2019
