ASUS VivoBook Max X441SC
Discussion in 'BIOS/UEFI' started by technical, Sep 5, 2016.
ASUS VivoBook Max X441SC 5 5 1votes
    BIOS
    Boardview Asus X441SC 2.1.fz
    • Processor
      Intel® Pentium® Quad-Core N3710 Processor,
      Intel® Celeron® Dual-Core N3160 Processor,
      Intel® Celeron® Quad-Core N3160 Processor,
    • Operating System
      Windows 10 Home
      Windows 10 Pro
    • Chipset
      Integrated Intel® CPU
    • Memory
      DDR3L 1600MHz SDRAM Onboard Memory, up to 4 GB SDRAM
    • Display
      14.0" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
      14.0" (16:9) LED backlit FHD (1920x1080) Glare Panel with 45% NTSC
      Support ASUS Splendid Technology
    • Graphic
      NVIDIA GeForce 810M , with 1GB VRAM
    • Storage
      Hard Drives:
      500GB 5400RPM SATA HDD
      1TB 5400RPM SATA HDD
      2TB 5400RPM SATA HDD
    • Optical Drive
      Super-Multi DVD
    • Keyboard
      Chicklet keyboard
    • Card Reader
      Multi-format card reader (SD/SDHC)
    • WebCam
      VGA Web Camera
    • Networking
      Wi-Fi
      Integrated 802.11b/g/n
      Integrated 802.11 AC
      10/100 Base T
      Bluetooth
      Built-in Bluetooth V4.0
    • Interface
      1 x COMBO audio jack
      1 x VGA port
      1 x USB 3.0 port(s)
      1 x USB 2.0 port(s)
      1 x USB-C Gen 1 (up to 5 Gbps)
      1 x RJ45 LAN Jack for LAN insert
      1 x HDMI
    • Audio
      Built-in Stereo W Speakers And Microphone
      ASUS SonicMaster Technology
    • Battery
      3 Cells 36 Whrs Battery
    • Power Adapter
      Plug Type :ø4 (mm)
      Output :
      19 V DC, 1.75 A, 45 W
      Input :
    • Dimensions
      348 x 242 x 27.6 mm (WxDxH)
    • Weight
      1.75 kg
    #1 technical, Sep 5, 2016
    Similar Threads - ASUS VivoBook X441SC Forum Date
    ASUS VivoBook S15 S530FA BIOS BIOS/UEFI Aug 12, 2019
    ASUS VivoBook 15 X540UV BIOS/UEFI Jun 14, 2019
    ASUS VivoBook Flip 15 TP510UA BIOS BIOS/UEFI May 12, 2019
    ASUS VivoBook Flip 14 TP401CA BIOS BIOS/UEFI May 12, 2019
    ASUS VivoBook Flip 12 TP203NAH BIOS/UEFI May 12, 2019
  3. 32ifix
    32ifix Well-Known Member
    i need bios
    need build, you have bios old ?
  5. 32ifix
    CHECK BIOS SIR..NO DISPLAY
  6. 32ifix
  8. JENTORIS
    JENTORIS Well-Known Member
    ec kbc please?
    ASUS X441SC
  10. JENTORIS
  11. brixlaptop
    brixlaptop Well-Known Member
    sir do you have boardview and schematic for x441sc rev. 2.1?
    current Unavailable
  13. lazaro.089
    lazaro.089 New Member
    I downloaded Bios but it didn't work
    This is my original.
  14. 01ifix
    this is your original bios clear me, post results if works
  15. toniblank
    toniblank Well-Known Member
    please clear me,,no display
    no display Please Programming bios new above and compare results
  17. toniblank
    same,,
  18. dikizahrudin
    dikizahrudin Well-Known Member
    I have same problem no display.
    On power supply show only 0.160 Amp.
    i was flash bios all file in this page
    i was change ic bios
    i was flash kbc on this page
    i was remove lan ic
    i was remove sound ic
    i chek all pl is show value normal.
    anybody cab help. Thanks
    • Haha Haha x 1
    old bios error what? you have save send i check.
  20. dikizahrudin
    Ok sir i will post the bios but maybe not now cause i was not in store right now.
  21. rasta24
    rasta24 Well-Known Member
    open asus X441SC_2.1.fz please
