ASUS ROG GL502VM (7th Gen Intel Core)
Discussion in 'BIOS/UEFI' started by technical, May 21, 2017.
  1. Rui Fortunato
    Rui Fortunato Well-Known Member
    send file bios have problem GPU i check.
    This bios is not for you, you do not read the comment ?
    problem for you is what ??
  3. Rui Fortunato
    my problem is the graphic card that not install, it is not detected as nvidia card, my board is a gl502vm rev2.1
  4. Rui Fortunato
    this one is working only dont detect the gpu as an nvidia.
    file this have clear me ? Please use bios not clear me
  6. Rui Fortunato
    i tried with a not clear me bios the result is the same, the graphic card is not detected as an nvidia.
    send photo motherboard i help check
  8. Rui Fortunato
    photo downloads from google ?
    not clear i no see any info...
  10. Higher Functions
    Higher Functions New Member
    Good morning, Thien.
    No success with this MAIN.
    Notebook starts without image to LCD with this ROM.
    check chip GPU
  12. Rui Fortunato
    Good Evening,
    Check the CPU, in my case the nvidia was present but didn't instal because the the intel gpu is off.
    laptop no display how to you can install ?
  14. Rui Fortunato
    Good morning Thien,
    The Clear me that you have done to me works fine on my mb, the only anomally is the fact that my nvidia don't install because the intel graphic card present on cpu is off. So the windows installs it as a microsoft basic graphic card.
    why above you say (Notebook starts without image to LCD with this ROM.) ?
  16. Higher Functions
    Good morning, Rui.
    Can you explain it in more detail?
    Graph of intel / CPU off where? How did you turn it on?
    So you got GTX turned on, driver installed and everything functional?
    Thank you.
    I can only explain if I have that computer in my hand and check it directly.
  18. Rui Fortunato
    The cpu got the graphic card off.
    #58 Rui Fortunato, Jul 19, 2019
  19. Higher Functions
    Boa tarde Rui.
    Sim, o meu pc liga com imagem!
    Sim, tenho uma placa gráfica básica da Microsoft.
    Sim, o ID do hardware é da Nvidia.
    Então você me diz que a imagem que eu vejo está a ser gerada pela Nvidia, certo? Ok!
    Como você fez para resolver o problema?
    Obrigado.
    Cumprimentos.
Similar Threads - ASUS GL502VM (7th Forum Date
ASUS GL502VMZ BIOS/UEFI Jul 11, 2018
ASUS ZX60VM BIOS GL502VML BIOS/UEFI Jul 11, 2018
Asus ROG GL502VM BIOS/UEFI Sep 3, 2016
