Apple iMac A1419 820-4652
Discussion in 'BIOS/UEFI' started by technical, Sep 18, 2016.
  1. Nenad63
    Nenad63 New Member
    Is it possible that the N25Q064A chip is bad, so I can check it out? Although the programming goes smoothly ... thanks
    iMac Intel 27
  3. Nenad63
    Nenad63 New Member
    I know where it is, but how do I check it?
    check what?
  5. Nenad63
    Nenad63 New Member
    N25Q064A Chip
    here is BIOS you need Programming, you say check what i not Understand. :(
    Are you a technician and know the BIOS programmer?
  7. Nenad63
    Nenad63 New Member
    Pictures while iMac was in use
      File size:
      799 KB
      17
      File size:
      454.5 KB
      9
      File size:
      413.4 KB
      18
      File size:
      1.3 MB
      12
      File size:
      296.4 KB
      18
    answer the question Please :
  9. Nenad63
    Nenad63 New Member
    Can I ask you to make Clear ME from Apple iMac A1419 820-4652-A.bin file ... please
    Clear me A1416 820-4652-A.bin
  11. Nenad63
    Nenad63 New Member
    Why A1416, not A1419 or is a mistake in writing
    only need same code 820-xxxx. :)
  13. Nenad63
    Nenad63 New Member
    Here's one more time. Most likely the bios dump does not fit my CPU: Intel Core i5 3.5Ghz .... can you fit it ...Sorry , I'm using a google translator...Can you make a Clean ME from an Apple iMac A1419 820-4652-A bin file, not from A1416 820-4652-A mx25L6406e.bin
    send file i help clear me.
    or use guile this.
    https://vinafix.com/resources/how-to-clear-me-region.1188/
    How to Clear ME Region
    The Intel Management Engine (ME), also known as the Manageability Engine, isan autonomous subsystem that has been incorporated in virtually all of Intel'sprocessor chipsets since 2008. ... It is a...
    vinafix.com
  15. gadgetfix
    gadgetfix New Member
    anyone have schematic or boardview for this? I have blown fuse not sure what spec?
    yes, Unavailable schematic
  17. 41ifix
    41ifix Well-Known Member
  18. 05ifix
    05ifix Moderator
    Got it!
    Here ya go!
    01ifix and 41ifix like this.
  19. 41ifix
    Nice bro +1
Similar Threads - Apple iMac A1419 Forum Date
Apple iMac A1419 820-3478-A BIOS/UEFI Dec 22, 2015
Apple Apple iMac 27 A1419 D8 051-9505 820-3299_051-9505 800 Schematics Jan 6, 2014
APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
820-00609-A Apple iMac 27" 5K Retina BIOS/UEFI May 26, 2018
Apple.HD6970M.2048.110128 (IMAC A1312 HD6970 2GB VGA ATI 216-0811000) ELECTRONIC DEVICE Sep 24, 2017
