Apple iMac A1419 820-4652
Discussion in 'BIOS/UEFI' started by technical, Sep 18, 2016.
Apple iMac A1419 820-4652 5 5 1votes
    Apple iMac A1419 820-4652-A
    BIOS Mid 2015
    • Like Like x 3
    Similar Threads - Apple iMac A1419 Forum Date
    Apple iMac A1419 820-3478-A BIOS/UEFI Dec 22, 2015
    Apple Apple iMac 27 A1419 D8 051-9505 820-3299_051-9505 800 Schematics Jan 6, 2014
    APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
    820-00609-A Apple iMac 27" 5K Retina BIOS/UEFI May 26, 2018
    Apple.HD6970M.2048.110128 (IMAC A1312 HD6970 2GB VGA ATI 216-0811000) ELECTRONIC DEVICE Sep 24, 2017
  3. Gurmeet bhatia
    Gurmeet bhatia Well-Known Member
    above bios not working
    not working how?
    old bios and macbook error what?
    Please provided many info where want i help.
  5. Gurmeet bhatia
    the customer original bios give giving display on USB and external after removing the internal LCD
    if you put the LCD the machine turn off / restart after the CHIME sound comes before the display .
    i want to try first with the working bios . then later i check other problems .
    bios above work 100% can only is Me Region problem, you can Clear me or send file old i help.
  7. hernan tangoa f.
    hernan tangoa f. Well-Known Member
    schematic and boardview please 820-4652-A
  9. Nenad63
    Nenad63 New Member
    The iMac worked on the extern display via the minidisplayport, after rewriting the dump with your dump file, only the first two LEDs are logging in, no sound. And unfortunately when I get my dump, the guy looks the same - dead. I'll send you your dump file, so I hope your help.Nenad
    A1416 820-4652-A mx25L6406e.bin
  11. Nenad63
    Nenad63 New Member
    Hope it is not a problem with chip model, 25Q064A is on my logic board
  12. Nenad63
    Nenad63 New Member
    Not this dump, they are not the same size
  13. Nenad63
    Nenad63 New Member
    do you still have an idea
    No problem, I want to know the results after programming ?
  15. Nenad63
    Nenad63 New Member
    Programming is OK, but iMac does not start....
    iMac 3.5 GHz Core i5 iMac iD 15.1
    Apple iMac A1419 Late 2014 Mid 2015 Mf886LL 27" Logic Board 820-4652-A 661-00191
    can have hardware error ?
  17. Nenad63
    Nenad63 New Member
    Unbelievably, until about an hour ago, iMac worked with an external display...
    now have work external display ? can give one photo.
    and can try add bios clear me i update on top.
  19. Nenad63
    Nenad63 New Member
    no, no external display now, only the fan starts and the first two LEDs..
  20. Nenad63
    Nenad63 New Member
    in any case, thank you for your help
  21. technical
    now BIOS old you send same problem not work ?
    check hardware all Please
