Apple APPLE A1286 820-2915-B
Discussion in 'BIOS/UEFI' started by technical, May 31, 2014.
  1. 01ifix
    gpu is same model as the damage ?
    (el gpu que cambiaste tiene la misma matricula que el dañado ? )
  2. 02ifix
    02ifix Well-Known Member
    Yes is the same !!!!
  3. 01ifix
    in some cases when i replace gpu new i prefer change solder balls to PB , other use lead free
    maybe with a reflow set more tempetature just litle more
    or maybe one pad have oxided and ball not make contact there
  4. 02ifix
    Do not think is faulty pad, i use PB too !!!
  5. 01ifix
    last week i have same problem maybe the chip bad (GPU)
    my customer take off machine so cant work anymore with this,
    if you have solve this issue let me know plz this problem is very comun in laptop mac late 2013
  6. 02ifix
    I have here 2 machines with the same problem :(
  7. 02ifix
    CPU and VGA replace and same thing !
  8. 01ifix
    so you think is mobo ?
  9. 02ifix
    yes i indeed think its a issue around componetery or even inner layer issues , when a motherboard of this model is not protected with kapton and alluminum tape the motherboard never stay ok again , NOW if i protect well the motherboard and leave only the gpu area open even after replace the motherboard stay working very nice . NOW if i dont protect motherboard it start havicng issues with grafics . (attention that even on does motherboard we've replaced the Vrams and the issue persisted , we've seen clocks , and vcores and even Csense , and all normal , even on does case we have been changing components with new ones , but same issue ... does board for what we can see here , they cannot stand much heat , getting all fucked around unless you protect weel the motherboard before making gpu exchange !
  10. ankit
    ankit New Member
    a1286 vga share at good price 100% working
  11. ankit
    ankit New Member
  12. 01ifix
    you mean ? plz explain more
  13. ankit
    ankit New Member
    serch on net harry7705
  14. ankit
    ankit New Member
    change chip for solution
  15. 01ifix
    i search but no reply you have for sell solution ?
  16. esmerlin
    esmerlin Well-Known Member
    I have this same motherboard pn 820-2915-b
    entry for video failure, make a reballing to the video chip and work correctly for 2 days, then I stop turning on the computer (leave the battery 1 hour disconnected and turned on) but now I do not work keyboard or mouse pad. (I've tried another keyboard, another mouse, another operating system)
    What can be?
    Need check all...
  18. Hit's Patni
    Hit's Patni Well-Known Member
    how to fix this error
    send me solutions
  20. Hit's Patni
Similar Threads - APPLE A1286 2915 Forum Date
Apple APPLE K91F K91X FLYING_DUTCHMAN 051-8620 820-2915 Macbook Pro A1286 Schematics Jul 6, 2014
APPLE A1286 MLB 820-2850-A BIOS/UEFI Oct 18, 2016
Apple Apple A1286 J31 051-9585 820-3330-B Schematics Jul 6, 2014
Apple APPLE K19 MLB 051-7892 A1280 A1286 820-2523-B A1287 Schematics Jul 6, 2014
Apple APPLE K18 MLB 051-8504 820-2850 051-7546 820-2330 A1286 Schematics Jul 6, 2014
