Apple A1502 820-3476-A Shematic
Discussion in 'Schematics' started by technical, Mar 20, 2015.
  1. vinafixspain
    vinafixspain Well-Known Member
    I appreciate your help.
    #21 vinafixspain, Feb 7, 2019
    try file this
  3. vinafixspain
    THANKS FOR YOUR ANSWER I JUST TESTED THE BIOS THAT HAPPENED TO ME AND IT DOES NOT WORK WELL TAKES A LOT IN THE SYSTEM OR WHEN YOU START IT, WITH YOUR ORIGINAL BIOS IT WORKS WELL UNIQUE DOES NOT HAVE A SERIAL NUMBER
    send file bios you say it slow?
  5. vinafixspain
    this is original BIOS works perfectly unique that does not have serial number
    it is possible that you can put me the serial number of the team SN: C02RK8HYFVH3
    i said forget this bios go it is not a native BIOS, Please use one bios new and provided resuilt.
  7. vinafixspain
    Thanks for your help but I have tried several and they do not work correctly.
  8. Padam
    Padam Well-Known Member
    booting stucked problem sir please fix it
    Programming one bios new and provided result
  10. Padam
    i will try but no fix can you suggest me new one please
    not fix how send one video problem
  12. b4tech
    b4tech Well-Known Member
    you have same another bored view
    other how ?
  14. b4tech
    i have brd file /have another format file ..yes or no
    no
Similar Threads - A1502 3476 Shematic Forum Date
APPLE A1502 emc2875, 2014-15 820-3476-A need BIOS BIOS/UEFI Jun 17, 2018
Apple BIOS MacBook A1502 820-3476-A BIOS/UEFI Apr 25, 2015
Apple Apple a1502 emc2678 820-3476-A BIOS/UEFI Dec 29, 2014
A1502 EFI Lock Password help BIOS/UEFI Aug 21, 2019
macbook pro A1502 bios !! help BIOS/UEFI Jan 18, 2019
