Apple A1466 820-00165 A
Discussion in 'BIOS/UEFI' started by 01ifix, Aug 7, 2016.
  1. johnninfor
    johnninfor New Member
    Hi, I am in my work, I installed the BIOS you edited and it did not work, the machine only works trackpad and keyboard when in the boot option, but within the system does not. Here is the original BIOS of the machine without modifications.
    bios old this have problem what ?
  3. johnninfor
    Sorry not to understand your English very much, I am using BING translator, this is the original bios of the machine without modifications, the machine has EFI lock, after cleaning and installing the system does not work Trackpad and keyboard, only works on the BOOT screen, when opens the System does not work.
    try file this.
  5. johnninfor
    not work :pensive:
    I made a video see >
    dimpu likes this.
  7. dimpu
    dimpu Well-Known Member
    technical likes this.
  8. Don1976
    Don1976 New Member
    I HAVE 2017 820-00165 that i tried to change the serial no to install the board to a different macbook. acidently I deleted the original bios and rewrite with known working bios which i did before. but fan spins no chime. I tried the bios you sent me early but same situation. when i pull a bios from another same board it boots but stuck in apple logo for ever. Can you send me clean bios file or can i clear me regeon of donner board bios?
    yes
    https://vinafix.com/resources/how-to-clear-me-region.1188/
  10. Don1976
    Don1976 New Member
    Hi, Thank you for your reply.
    I know to clear me regegeon but I dont have the clear file. I hve old bios file which is getting stuck so can me send me the link to clear me bios bin or can you clear me regeon of attached file please. its 820-00165 , 2017 emc 3178. thanks
  11. 01ifix
    here file use it for clear me
  12. Don1976
    Don1976 New Member
    Hello Thienbui,
    Can you please send me the clean me bin for the above attached bin file or clean me regeon of that file.? Im stuck for days as nothing works. when I tried from another same board bios it works but takes such a long time to boot.
    here me region you can try
  14. 38ifix
    38ifix Well-Known Member
  15. Babatunde E Olugbemi
    Babatunde E Olugbemi Well-Known Member
    can you fix me this apple air bios dump,it is slow in booting and sometimes not booting unless you do nvram reset.Motherboard number:820-00165-a ,MLB 1.6G I5 8GB
    try file this
  17. icalfixit
    icalfixit New Member
    Halo master ThienBui
    need unlock efi 820-00165-A
    thank you :)
  19. teknisibelajar
    teknisibelajar Well-Known Member
    please clear me
    clear me
Similar Threads - A1466 00165 Forum Date
A1466 820-00165-A BIOS/UEFI Apr 23, 2017
Macbook Air 13 inch A1466-EMC 2925-820-00165-A-Early 2015 BIOS/UEFI Jan 4, 2017
Apple A1466 820-00165-02 2015 BIOS/UEFI Jun 24, 2015
Apple A1466 Schematics Dec 17, 2018
A1466 BIOS/UEFI Oct 15, 2018
