Apple A1466 820-00165 A
Discussion in 'BIOS/UEFI' started by 01ifix, Aug 7, 2016.
  1. dam1inc
    dam1inc New Member
    Hello Sir, I need help i have A1465 EMC 2924 i received, BAD EFI FLASH, No Original Dump, i try use many .bin for 820-00164-A but device always stuck on Apple Logo with white progress bar. What is this problem and how to solve sir.
    Thank you
  2. 01ifix
    maybe need clear me
    BOICU CONSTANTIN likes this.
  3. dam1inc
    dam1inc New Member
    Hey thanks for the response, I was thinking that was a possibility but wasn't sure because ive never had to do that so I guess I'll give that a shot and post results
    Thank you [emoji106]
    Sent from my SM-G955U using Tapatalk
  4. dam1inc
    dam1inc New Member
    This worked for me @B4RDOCK thanks
  5. 01ifix
    good,
  6. nymphetamine52
    nymphetamine52 New Member
    Hello friends! Greetings from Slovakia!
    I need help with unlock this dump. Can somebody help?
    I`ve tried many dumps which works but extreme slow. Maybe ME problem.
    Thank you
  8. hgzy ahmd
    hgzy ahmd Well-Known Member
    please how to remove password from attached bios
  10. 03ifix
    TRY THIS AND REPLY.
    hgzy ahmd likes this.
  11. hgzy ahmd
    thanks very much password removed and bios good working
      File size:
      76.5 KB
      8
  12. SDRAM1V1
    SDRAM1V1 New Member
    how can you write a fil of 8M TO AN EEPROM 25P32 OF 4MB SO SAD
  13. 01ifix
    what programmer you have ? i use RT809H
  14. SDRAM1V1
    SDRAM1V1 New Member
    ITS NOT A PROBLEME TOOLS RT809 AND TL866 CAN EASY READ AND REWRIT
    THE REAL PROBLEM IS THAT SOM CHIP OR SOME EEPROM IC ARE PROTECTED FROM REWRITING WISH MEAN THAT YOU HAVE TO CHANGE YOUR EEPROM IC WITH ANOTHER ONE
  15. 01ifix
    well in my case still not arrive any mobo with thic eeprom, protected ,
  16. SDRAM1V1
    SDRAM1V1 New Member
    HAVE YOU FORGET YOUR LAST POST WISH EXPLAINE CLEAR THAT YOU HAVE BEEN ENABLE TO REWRITE YOUR DUMP GN
  17. 21ifix
    21ifix Moderator
    because your method is wrong
    you need to have the method right to unlock
  18. 21ifix
    21ifix Moderator
    unprotect , i still can unlock it perfect
  19. SDRAM1V1
    SDRAM1V1 New Member
    i know your are an engineer man good luk
  20. 01ifix
    hi in the error i have was about my old programmer dont detect correctly the chip eepro, now with RT809H i have no problem with any eeprom , if are protected for write but can read back up dump ,and use same bios dump
    if you are talking about efi password i can unlock it also
    try use 1.8 volt adapter for can read and write good
Similar Threads - A1466 00165 Forum Date
A1466 820-00165-A BIOS/UEFI Apr 23, 2017
Macbook Air 13 inch A1466-EMC 2925-820-00165-A-Early 2015 BIOS/UEFI Jan 4, 2017
Apple A1466 820-00165-02 2015 BIOS/UEFI Jun 24, 2015
Apple A1466 Schematics Dec 17, 2018
A1466 BIOS/UEFI Oct 15, 2018
