Apple A1398 820-3787-a
Discussion in 'Schematics' started by technical, Dec 21, 2014.
  1. 10ifix
    10ifix Moderator
    I DNT KNOW PLS DO IT U CAN DO PLS BRO
  2. 10ifix
    10ifix Moderator
    hi , can you please unlock pin code in this firmware. thanks
  3. 10ifix
    10ifix Moderator
    MX25L6405_20170409_171256_Unlock.BIN
  5. gagan rajput
    gagan rajput New Member
    Hello, do you happen to have working efi image for it, everytime I change the ME regions to the clear one, system does not display and fans run on high speed or do you know the way around that ? please let me know.
    Thank you
    How?
    You Clear me but not work ?
  7. gagan rajput
    I downloaded the efi for EMC 2881, flashed it and system was running very slow, so I analyzed and me version was 9.0.5.1367, so I copied that on the bin file but after that system chimes but no display and fans on high speed.
    give full code 820-xxxx I try.. and bios old error what ?
  9. gagan rajput
    board number is 820-3737, it is not giving any error while flashing, system just does not boot as intended, you had uploaded bios with clean ME and someone had same issue with it, so I thought you might know what be the cause of it.
  10. gagan rajput
    nevermind, I got it figured out. Thank you
  11. 12ifix
    12ifix Moderator
    how to read this bios? and what name of the bios if i use rt809h?
    where should i put pin spirom wp and spirom hold?
    #32 12ifix, Aug 15, 2017
    not sure i use TL866 :p
  13. 12ifix
    12ifix Moderator
    what does the ic detected?
    25xxxxx or what?
    my u6100 is 25l8005
    so i suggest the bios is in u1100(lynxpoint mobile fcbga).
    can you help how to read this fcbga?
  15. 12ifix
    12ifix Moderator
  16. selim yazıcı
    selim yazıcı Well-Known Member
    Hi,I want to BİOS 820-3787-A EMC 2881 ( A1398 MİD 2014 İ7 2.5)
    Please help
    above.
  18. kitouni
    kitouni New Member
    hi admin i ned your help . i ned ME for MacBook Retina 820-3787-A
