820-00687-A
Discussion in 'BIOS/UEFI' started by technical, Jan 13, 2018.
  1. krjavi
    krjavi New Member
    Can I use 820-687-a file on a 820-687-b board?
    yes, can
  3. krjavi
    krjavi New Member
    I used the file 820-687-a on my 820-687-b board and it turns on very very slow.
  4. chipmunk
    chipmunk Well-Known Member
    Use Medusa to clean ME, after that it will work.
  5. Sebb
    Sebb Well-Known Member
    Hi ThienBui,
    The bios that you posted is it a clean dump one?
    If not, is it possible to send you my bios bin and clean it up for me, please?
    Thanks.
    yes, buy one VIP and get support
    Account Upgrades
  8. Sebb
    ThienBui, you are amazing!
    All worked perfectly fine.
    Thanks again friend!
  9. Sebb
    Everyone who is using EFI BIOS SPI flex cable (without removing the chip from the board), make sure that the cable is making a good connectivity between pins and the programmer.
    It happened in my case to not be able to read or write.
    Just find the right orientation/position.
    And also, after the whole process, make sure that you reset the nvram for 2-3 times, because some times pieces of information gets stuck and it acts weird (boot loops, black screen, stuck on logo, starts very slow) and this might fix.
    In rest, good luck guys!
    #29 Sebb, Jul 23, 2019
Similar Threads - 00687 Forum Date
Apple Logic Board 820-00687 Bios BIOS/UEFI Jan 13, 2018
