Review CF360T Intelligent Mute BGA Rework Station
Discussion in 'Computer Hardware Repair' started by technical, Dec 28, 2014.
    CF360T Machine Parameter: Main Power:4000W Upper heating power: 800W Bottom heating power:
    800W Power supply: AC220V±0.1 50/60Hz Overall dimension: 760mm(L)*700mm(W)*600mm(H) Location mode: PCB holder can be adusted to X/Y direction at will , clip slot of V font , crocodile clip, hook of V font. Temperature Control: Closed-Cycle control with K Sensor, independent temperature control, precision:±1. PCB Size: W50*D50mm~ w440mm*D310mm Suitable Chip Size: 2*2mm-46*46mm Upper Nozzle Size: 28mm*28mm,35mm*35mm,38mm*38mm ,43mm*43mm , 46mm*46mm Bottom Nozzle Size: 34mm*34mm,45mm*45mm Manner of Working: Drive Machine Weight: 36KG - See more
    PLC controller is the inland famous brand DaGong, precise temperature-control, and can realize intelligent mute & automatic warning. The warranty of PLC temperature-controller is 2 years. - See more
    The design of inner notch can ensure to clip PCB and mounting hole of nobebook-board firmly, make PCB not easily to be shapeless when heating. Extra Strength upper heating support, removes more flexible. - See more
    Alvien_nvix and digitaal88 like this.
    Similar Threads - Review CF360T Intelligent Forum Date
    MacOS Sierra Review, Release Date. Apple - macOS Jun 14, 2016
    PhotoReviewer Apple - macOS Jun 5, 2015
    Review RT809F Serial ISP USB Universal EPROM FLASH Programmer Computer Hardware Repair Dec 28, 2014
    Review CF260 BGA Rework Station upgrade Computer Hardware Repair Dec 28, 2014
    Trải nghiệm nhanh Windows 10 Technical Preview Windows PC Oct 3, 2014
  3. 01ifix
    looks great machine, i have shuttle star 360pc v3, its good too
