Diagnostic Card Laptop / Desktop
Discussion in 'Motherboard' started by technical, Dec 26, 2014.
Diagnostic Card Laptop / Desktop 5 5 2votes
5/5, 2 votes
    technical Moderator
    NTRODUCTION
    The Desktop / Notebook Diagnostic Card is a powerful diagnostic tool for technicians and
    administrators to troubleshoot various problems of notebook PC PII/III/ P4 by using a PCI and
    LPT (printer port) Bus. It is easy to install, yet extremely powerful to use. With this card in hand,
    you no longer have to go through tedious and time consuming process of trying to figure out what
    is wrong with your hardware. Notebook Diagnostic Card will indicate exactly what is wrong with
    your notebook in just seconds. It saves your time and money.
    - Our new and improved design of Diagnostic Card, it can work with almost all popular types of
    CPUs, Motherboards, and BIOS.
    All though we try, it is not possible to update this manual every time a new motherboard is made
    by the manufactures. It is always advised to visit the bios manufacture website, and download the
    latest codes per bios revision. Or visit bioscentral.com for an online reference.
    System Requirements
    The Desktop / Notebook Diagnostic Card itself only requires an empty PCI slot or LPT port
    connection. It is not necessary to install memory chips to perform analysis. “POST Codes” can be
    displayed through the hexadecimal display panel.
    Desktop / Notebook Diagnostic Card INDICATORS
    ‘Indicators’ are any light emitting diodes(LED) or hexadecimal display panel is mounted on
    extended cable. This section discusses the following indicators that appear on the Notebook
    Diagnostic Card:
    Desktop / Notebook PCI & LPT Printer Port Bus Card
    POST Code Display
    The POST Code Display is made up of a dual, dot matrix hexadecimal read-out that displays
    Power On Self Test (POST) status codes.
    Power On Self-Test (POST) Codes
    This card can test the AMI/AWARD/PHOENIX BIOS, while it can be used in widely model of
    notebook. During system booting up, this card displays can show the post codes. Refer to
    Appendix A, it shows almost POST codes provided by BIOS manufacturers.
    PCI Signal Definition:
    FRAME PCI Bus Frame. Should be on under normal circumstances and flashes
    when a PCI Frame Signal is detected.
    CLK Motherboard Clock Signal. Should be on when power is supplied to the
    motherboard even without CPU.
    12V Power Supply, 12-Volt Positive. Should be on all the time otherwise there
    is a short circuit.
    -12V Power Supply, 12-Volt Negative. Should be on all the time otherwise there
    is a short circuit.
    +3.3 Motherboard Clock Signal. Should be on when power 3.3V is supplied to
    the motherboard even without CPU.
    Installation Procedure
    TO INSTALL A Diagnostic Card:
    1) Install the Notebook Diagnostic Card in PCI slot or LPT Printer Port
    2) Power on the machine and monitor the code shown on LED
    3) When using the LPT printer mode, USB cable must be used to supply power to PC
    Diagnostic card. USB cable not required when using PCI slot mode.
    4) Install JP2 External Speaker Connection if required, see note below.
    5) Observe POST CODE.
    POST Codes
    When the machine is turned on, the hexadecimal display should show the various POST codes
    (Post 80H + 84H) as the system executes (unless it has a rare BIOS that does not display POST
    codes).
    If the machine does not boot, system POST has detected a fatal fault and stopped. The number
    showing in the hexadecimal display on the Notebook Diagnostic Card is the number of the test in
    which POST failed. Refer to Appendix A for a listing of POST codes.
    Troubleshooting During POST
    After initial power up, Power-On Self-Test (POST) codes begin displaying on the Notebook
    Diagnostic Card’s hexadecimal displays (for most machines).
    THE POST PROCESS
    The ROM built onto the motherboard of the computer rums its built-in POST (Power-On Self-Test)
    when you switch power on to the computer, press the reset button on the computer, or press
    Ctrl-Alt-Del (warm boot). POST performs a tightly interwoven initialization and testing process
    for each of these methods, but it typically does not test or initialize memory above 64K for warm
    boot. You can get an even better idea of the detailed process by studying the POST code listings in
    Appendix A.
    JP2 EXTERNAL SPEAKER CONNECTION
    On some older motherboards you may encounter no onboard speaker or non functional
    motherboard speakers. Use the 2-pin gray jumper wire included to jump the connection from the
    speaker terminals on the motherboard header to the JP2 jumper on the PC POST Card. This will
    connect the onboard speaker of the PC POST card so you can hear BEEP CODES as well as see
    POST CODES.
    Error Code
    Award (Edition: ELITEBIOS 4.51PG)
    C0 Turn Off Chipset Cache
    01 Processor Test 1
    02 Processor Test 2
    03 Initialize Chips
    04 Test Memory Refresh Toggle
    05 Blank video,Initialize keyboard
    06 Reserved
    07 Test CMOS Interface and Battery Status
    BE Chipset Default Initialization
    C1 Memory Presence test
    C5 Early Shadow
    C6 Cache Presence test
    08 Setup low memory
    09 Early Cache Initialization
    0A Setup Interrupt Vector Table
    0B Test CMOS RAM Checksum
    0C Initialize Keyboard
    0D Initialize Video Interface
    0E Test Video Memory
    0F Test DMA Controller 0
    10 Test DMA Controller 1
    11 Test DMA Page Registers
    12~13 Reserved
    14 Test Timer Counter 2
    15 Test 8259-1 Mask Bits
    16 Test 8259-2 Mask Bits
    17 Test Stuck 8259’s interrupt bits
    18 Test 8259 Interrupt Functionality
    19 Test stuck NMI Bits
    (Parity/IO check)
    1A Display CPU Clock
    1B-1E Reserved
    1F Set EISA Mode
    20 Enable Slot 0
    21-2F Enable Slots 1-15
    30 Size Base and Extended Memory
    31 Test Base and Extended Memory
    32 Test EISA Extended Memory
    33-3B Reserved
    3C Setup Enabled
    lorins_core likes this.
    Similar Threads - Diagnostic Card Laptop Forum Date
    INFOCUS LP650 Diagnostics_Troubleshoot_Trees Schematics | Document May 22, 2015
    R9 255-2GD3 DP CARD Desktop Schematics Nov 4, 2015
    R5 235X-1GD3 DP CARD Desktop Schematics Nov 4, 2015
    ASUS G3S 1.0 G3S MXM CARD NB8E-SE Schematics Oct 31, 2015
    DIAG_BATT_EMU DIAG_CARDBUS_LAN DIAGS_4 DIAGS_USBLED Schematics Oct 27, 2015
  3. takedos
    takedos New Member
  4. lorins_core
    lorins_core New Member
    very nice
Share This Page
