XPS 13 9350 LA-C881P
Discussion in 'XPS' started by technical, Oct 8, 2015.
XPS 13 9350 LA-C881P 4 5 2votes
4/5, 2 votes
    DELL XPS 13 9350
    aaz80 la-c881p 25Q128BV
    I5-6200U
    #1 technical, Oct 8, 2015
    Similar Threads - 9350 C881P Forum Date
    Dell Dell Xps 13 9350 (LA-C881P Rev1.0) BIOS/UEFI Jan 25, 2018
    Dell XPS 13-9350 - AAZ80 LA-C881P REV:2 BIOS/UEFI Feb 27, 2017
    DELL XPS 13 9350 AAZ80 LA-C881P schematic Schematics Oct 18, 2016
    XPS 13 9350 AAZ80 LA-C882P Rev 0.2(X01) BIOS/UEFI Mar 11, 2019
    BIOS PC M9350Z N000 IQ87SE REV 1.0 BIOS BIOS/UEFI Nov 27, 2017
    Dell XPS13-9350
    AAZ80 LA-C881P 25Q128BV
  4. Đào Hưng
    Đào Hưng Well-Known Member
    con này anh có clear me ko
    Dell XPS13-9350 AAZ80 LA-C881P
    Clear me
  7. MCSCOM
    MCSCOM Well-Known Member
    bios for i7-6500U SR2EZ ? i5 version doesn't work
    bios old error what ?
  9. MCSCOM
    its blank screen when you put i5 bios in to i7 board. I need i7 version
    no problem i5,i7. bios old error what ?
  11. MCSCOM
    keeps restarting after few sec on old one, on the i5 bios is blank screen
  12. bkjnotebook
    bkjnotebook Well-Known Member
    please ec
    LA-C881P
  13. tilon kamrul
    tilon kamrul Well-Known Member
    Admin I Have i7-6500U ULT 2.5G 4M .. When i write Dell XPS13-9350 AAZ80 LA-C881P Clear me.. then Its Blank screen .. its only 400ma on my power ,.. i upload my old bios dump .. i need i7 version bios ..
    bios you send error what?
  15. tilon kamrul
    all bios for me above same one problem, I think can have one error other.
  17. macabi170
    macabi170 Well-Known Member
    I programmed with this clearME file, now laptop boot to Dell Security Manager.
    before I this file, the laptop turned on with black screen, so I don't know if it has a password on it before, and also my client don't think he puts a password.
    I think this file had a password before? does someone has a good bios without password, and with a clear ME region?
    my model is XPS13-9350 AAZ80 LA-C881P Rev.1.0 (A00) intel core i7
    is it possible to build a good bios from Dell website that will work with a programmer, or I must use my old bios dump?
    I also tried first this file with a new Winbond 128b chip, laptop won't turn on at all, but when I put this file on the the original that had on board - KHIC Chip, laptop turned on with the password.
    is SPI ROM chips not the same for all? if it's the same size? because I always prefer not to mess with the original chip
    I uploaded my bios dump, if it helps?
    I check all BIOS above but I not see you downloads and Programming ?
  19. macabi170
    Yes I have download this Dell XPS13-9350 AAZ80 LA-C881P_Clear me.bin.zip, which was the only one that work, but it has a bios password, so now laptop works, but locked with password
    Try bios this, but I think password can in MEC...
  21. MCSCOM
