Toshiba Satellite L50-B
Discussion in 'BIOS/UEFI' started by technical, Aug 29, 2015.
Toshiba Satellite L50-B 5 5 1votes
    Satellite L50-B
    PSKT4E, PSKT4F, PSKT6E, PSKTAE, PSKTAV, PSKTCE, PSKTCV
    Satellite C55-B
    PSKT4F, PSKT4V, PSKT6V, PSKTAV, PSKTCV
    BIOS Kairos10SU (T) 10SU10SUG BIOS V2.00
    #1 technical, Aug 29, 2015
    Similar Threads - Satellite Forum Date
    Toshiba Satellite P855-S5200 P850-S5200 BIOS BIOS/UEFI Jul 18, 2019
    Satellite A305-S6829 (PSAG0U/PSAG4U) BIOS BIOS/UEFI May 30, 2019
    SATELLİTE C55-A-14H PSCGAE-01R00ETE BIOS/UEFI Apr 11, 2019
    satellite radius l40dw-c esac(l) mb rev 2.1a BIOS/UEFI Apr 2, 2019
    Satellite S55-B5201SL BIOS BLID BIOS/UEFI Mar 30, 2019
  4. tam tran
    tam tran Well-Known Member
    Ad cho xin bios L50-B PSKTCL. DABLIDMB8E0 REV:E. Thanks
  6. tam tran
    Tình trạng Bios cũ không lên hình nhưng vẫn tắt được. Còn Bios này thì không tắt được luôn.
    Nhiều file thế mà không chạy thì khó nói... :p
  8. 05ifix
    05ifix Moderator
    Hy , L50-B-2CP PSKTCE-04Y005G6 , DABLIDMB8E0 REV:E , i3-4005U , AMD Radeon™ R5 M230 1GB ,
    i tested the bios from first post, but when instal all drivers, no video after restart.
    Can you help me with other version ?
    I have original dump if you need
    can need check GPU.
  10. 05ifix
    05ifix Moderator
    I only chage the bios , not change the second 1kb memory,
    But the dump from first post , is 100% sure that will work with my laptop ?
  11. ormcra
    ormcra New Member
    KBC File?
    KBC name or file old.
