N21 Chromebook (Lenovo)
Discussion in 'LENOVO' started by technical, Aug 17, 2018.
    BIOS
    Similar Threads - Chromebook (Lenovo) Forum Date
    N20 Chromebook (Lenovo) LENOVO Aug 17, 2018
    N20p Chromebook (Lenovo) LENOVO Aug 17, 2018
    N22 Chromebook (Lenovo) LENOVO Aug 17, 2018
    N22-20 Touch Chromebook (Lenovo) LENOVO Aug 17, 2018
    N23 Chromebook (Lenovo) LENOVO Aug 17, 2018
  3. jou
    jou New Member
    The bios download for this model is available?
    you have motherboard code ? and old bios error what ?
  5. jou
    jou New Member
    Hello, motherboard model is: danl6lmb6b0, I still do not have error code, the problem of the bio is: it starts a little flash on the screen and does not give an image.
    send i file bios old i try build one bios new
  7. jou
    jou New Member
    Hi, I have a compressed file with two readings and images of the motherboard, Thanks.
    clear me
  9. jou
    jou New Member
    Thanks, I'll try it and comment.
  10. jou
    jou New Member
    It generates error when programming, I tested twice. What I can do?
    tool you use ?
  12. jou
    jou New Member
    With minipro TL866CS error when programming, with SVOD3 correct programming, but the board continues with the same fault. (Without image)
    check again all hardware .
  14. jou
    jou New Member
    Thanks I will check everything again
  15. KaniniTech
    KaniniTech Well-Known Member
    need this model bios lenovo chromebook n21
    motherboard code DANL6LMB6B0 REV : B
    problem some time no display
    i attach old bios
    need in english language
  17. MUHAMMAD HAQ MEER
    MUHAMMAD HAQ MEER Well-Known Member
    this bios works but i need same bios english language
    language can change in CMOS
