Lenovov V310-14IKB - V310-15IKB
Discussion in 'BIOS/UEFI' started by technical, Aug 30, 2016.
Lenovov V310-14IKB - V310-15IKB 5 5 1votes
    Lenovov V310-14IKB, V310-15IKB
    BIOS
    Lenovo V310-14IKB, V310-15IKB, V510-14IKB, V510-15IKB
    f1b525b59cda7121c9507a59298be1b4._.
    Similar Threads - Lenovov V310 14IKB Forum Date
    IBM-Lenovo Lenovo V310-15IKB model 80T3 DA0LV6MB6F0 rev:F BIOS/UEFI Mar 5, 2019
    BIOS PC X58V310 BIOS/UEFI Oct 6, 2018
    BIOS PC V310z All-in-One (Lenovo) BIOS 16556-1 BIOS/UEFI Aug 4, 2018
    SONY SVF11N15SCP 1P-013B500-8011 REV 1.1 V310 MB BIOS/UEFI Apr 12, 2017
    Lenovo V310-14ISK, V310-15ISK - DA0LV6MB6F0 BIOS/UEFI Aug 30, 2016
  3. nacres
    nacres Well-Known Member
    Hi,
    V310-15ISK and v310-15IKB motherboard numbers are same(da0lv6mb6f) but even though when I use v310-15ISK bios for v310-15IKB it doesnt work
    I tried the bios v310-15IKB which is working properly for the motherboard which is not working,i realized after 30 seconds it starts to work, please see the back up for the bios for the working device, if you have a bios for 310-15IKB Could you please send?
    IMG_1599. IMG_1598. IMG_1600.
    here
    https://vinafix.com/threads/lenovo-v310-14isk-v310-15isk-da0lv6mb6f0.24018/
  5. nacres
    We tested the bios there, not opening.
    I copied v310-15IKB bios from the computer that worked fine.
    I'm trying to open after 30 seconds.
    It's opening after 30 seconds.
    Now error what ?
  7. nacres
    do you bios clear me to you
  8. nacres
    V310-15IKB_Clear me.BIN
  10. nacres
    V310-15IKB_Clear me.BIN.zip not working.
    What is the difference between the bios that opens 30 seconds late and the bios you throw?
  12. nacres
    Your bios do not work.
    Are you sure bios are working?
    I give you bios working, you are doing clear me, it is not working.
    BIOS above is you send me
    you need sure is work or no ??
  14. nacres
    the same model, but the bios that I cloned from the running device is booting up but after 20 seconds the image is coming.
    I sent you the original working bios, you bios clear me , then it never came to work.
  15. nacres
    The bios I send you is working but the image is late.
    Intel me region Can it be done?
    Return this bios and create a video after 20 seconds display... i need check..
  17. nacres
    I will send it soon
  18. nacres
    the video you want
  20. nacres
  21. technical
    not work what ?
