Hi! I have replaced a defect mainboard with a used one and now i need to change the service tag back to original. System is dell E7440 LA-9591P. Is this possible only with kbc change?
Update #2 Done reading ;-) Code: MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280000000C Boot Block in protected mode MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280000000C Boot Block in protected mode Start erase in: 25.03.2018 14:58:52 End erase in: 25.03.2018 14:58:53 Erase OK
I`ve found an ECE5048. This one? But there is no pinout i can find in the schematic. If there is a working solution i would also pay for VIP no problem!
SVOD2 ECE Mode Code: Software version 1.0.2.9 date 21.03.2018 Running Microsoft Windows 7 Professional 64 bit Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz Device connected in work mode Firmware version 1.0.2.0 date 10.3.2018 MEC mode selected MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280000000C Boot Block in protected mode MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280000000C Boot Block in protected mode Start erase in: 25.03.2018 14:58:52 End erase in: 25.03.2018 14:58:53 Erase OK Start reading: 25.03.2018 14:58:58 End reading: 25.03.2018 14:59:00 CRC calculated 0 CRC stored FFFF Read OK MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280400000C Boot Block in protected mode MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 280000000C Boot Block in protected mode Start erase in: 25.03.2018 14:59:20 End erase in: 25.03.2018 14:59:20 Erase OK MEC IDCODE: B1240020 Device ID: 12 Device Revision: 0 Device Status: C Flash Status: 290500000C Boot Block in protected mode Start erase in: 25.03.2018 14:59:32 End erase in: 25.03.2018 14:59:33 Erase OK Start blank check: 25.03.2018 14:59:33 End blank check in: 25.03.2018 14:59:35 Blank Check OK File size : 196608 Flash size :196608 Start writing: 25.03.2018 14:59:35 End writing in: 25.03.2018 14:59:38 Write OK File size : 196608 Flash size :196608 Start verify: 25.03.2018 14:59:38 End verify in: 25.03.2018 14:59:40 Verify OK The dump is attached ;-)
1) EXTEDNER The extender is only a combination of cheap china fpc to dupont adapter and self created 3d model printed in [email protected]. Nothing special. You need solder skills to put the dupont pins on the adater and also the fpc connector. In this case 10pin with 0.5mm pitch. You need also 10pin 0.5mm fpc ribbon cable. last part is to solder an fpc connector to the mainboard. Much easier way then to struggle around with single wires in 0.5mm pitches! You could also use the original keyboard connector from the svod2 package, but especially for this board my solution is much nicer to handle. 2) MEC5075 I have not figured out how this has happend 100% because the mec5075 is 256Kb and not 192Kb like my dump. This will be fixed in the SVOD2 Software hopefully during the next days. So i cannot explain how it was working for now. I will try it again with a fixed software version. But it seems to be a combination of erasing the mec and bring the bios to factory defaults ;-)
MEC5075/5085 Default Files: Offset 0-1000 & 3FFFC-48000 could contain write errors during flashing, but the system should work! Don`t forget to make a backup for disaster recovery....
