Hello guys, I have this mobo /and whole notebook/ for diagnostics /and repair if I can /. There is no schematic for U93, so I'm using U72 DC-JACK is broken so I guess there are 19V on AD_ID line. 3.3V/5V - RT8223P was very hot, so replace it with TPS51125. Replace dcjack cable. When plug adapter, orange diode blink for a second and that's it. When pressing power button, voltage drop form 3.3 to 0. I try to check AD_ID line. I found R336 and replace it, but I can't find R344 and D8 diode. On R336 I have 1.08V at one side, and 0V on other side. Can someone tell me where is R344 located /if it's present on this board/ Some measurements: --------------------------------- IT8528E: 11-0 21-3 24-3.4 25-3.4 26/50/92/114/121-3.4 74-0 110-3.4 111-3.4 123-2.2 124-3.4 125-0, even after pressing power button 127-0 ------------------------------ BQ24728 /pu2/-charger 20-19.5 4 /acdrv/ 25.5 ??? 5-3 6-2.7 8-3.4 9-3.4 ------------------------------ 3/5VPCU RT8223P /replace with TPS51125 8 /vreg3/ - 7.8 ??? 17 /vreg5/ - 5 13 /en0/ - 3.2 16-19.5 PL20-5 PL21-3.3 -------------- Edit with additional info: after replacing IT8528, dcjack led lights white, notebook power on, but there is no picture and fan no spinning. I check PU9 /NB671, code on the chip AEAD 748, I think it's this one: https://www.monolithicpower.com/DesktopModules/DocumentManage/API/Document/getDocument?id=823 Client Challenge monolithicpower.com I check this from Quanta 92 schematic, because on Quanta 72 i think it's different IC. On pin 13 must be VRON from IT8528 /same signal goes to cpu power/, but there is 0v on NB671. VIN present. VRON /3.3v/ goes to NB671 through resistor PR282, but I can't find it on the board. Can someone help me where to find it? For testing - make a bridge from IT8528, pin 83 to NB671. After that, NB671 generates 1.2V, but still no picture on the screen. I need an advise..
