Honton HT R390 Manual
Discussion in 'Computer Hardware Repair' started by technical, Nov 26, 2014.
    HT-R390.
    HT-R390 Specification:
    Rated Power: 3800W
    Rated voltage: AC220V / AC110V optional
    The first upper zone power: 800W
    Second temperature lower power: 800W
    Lower part of the preheating temperature zone Power: 2200W
    Dimensions: L500mm * W420mm * H550mm
    Weight: 28KG
    Temperature control: high-precision closed-loop control of K-type thermocouple
    PCB positioning: V-shaped slot, PCB holder can be X, Y direction adjustment
    Can clamp PCB size: Max: 20mm * 20mm, Max: 320mm * 375mm
    Scope: BGA, PBGA, CBGA, CFP, CPU, CSP, which are lead-free rework
    Similar Threads - Honton R390 Manual Forum Date
    Honton HT R392 Computer Hardware Repair Dec 11, 2014
    Honton HT-R490 Manual Computer Hardware Repair Nov 26, 2014
    Sony sony VGN- NR390 BIOS/UEFI Jan 6, 2015
