Asus ASUS ROG G751JY
Discussion in 'BIOS/UEFI' started by technical, Aug 10, 2015.
Asus ASUS ROG G751JY 5 5 1votes
    ASUS ROG G751JY
    Similar Threads - ASUS G751JY Forum Date
    ASUS G751JY R2.5 BIOS BIOS/UEFI Jan 22, 2020
    Asus Rog G751JY Rev 2.5 Main Bios BIOS/UEFI Apr 9, 2019
    Asus Rog g751jy Computer Hardware Repair Jan 30, 2017
    • Processor
      Intel® Core™ i7 4860HQ /4710HQ Processor
    • Operating System
      Windows 8.1 Pro
      Windows 8.1
    • Chipset
      Intel® HM87 Express Chipset
    • Memory
      DDR3L MHz SDRAM, up to 32 G
    • Display
      17.3" 16:9 IPS FHD (1920x1080) anti-glare
    • Graphic
      NVIDIA® GeForce® GTX980M with 4GB GDDR5
    • Storage
      - 1TB HDD 7200 RPM With 256 G SSD
      - 2TB HDD 5400 With 128 G SSD
      - 1TB HDD 5400 With 8 G SSD
      Dual HDD Support(Optional)
      RAID0 Support (Optional)
      HDD Housing for 2ND HDD expansion
    • Optical Drive
      Blu-Ray DVD Combo
      Super-Multi DVD
      Blue-ray Writer
    • Card Reader
      2 -in-1 card reader ( SD/ MMC)
    • Camera
      HD Web Camera
    • Networking
      Integrated 802.11 a/b/g/n/ac
      Built-in Bluetooth™ V4.0
      10/100/1000/Gigabits Base T
    • Interface
      Headphone / surround out
      1 x Microphone-in jack
      1 x Headphone-out jack (SPDIF)
      1 x VGA port/Mini D-sub 15-pin for external monitor
      4 x USB 3.0 port(s)
      1 x RJ45 LAN Jack for LAN insert
      1 x HDMI
      1 x Thunderbolt port
      1 x SD card reader
      1X AC adapter plug
    • Audio
      Built-in Speakers And Digital Array Microphone
      Built-in subwoofer
      MaxxAudio support
    • Battery
      8Cells 6000 mAh
    • Power Adapter
      Output :
      19.5 V DC, 9.23 A, 230 W
      Input :
      3/ 2 pin compact power supply system
    • Dimensions
      416 x 318 x 20 ~53 mm (WxDxH) (w/ 8cell battery)
    • Weight
      4.8 kg (with 8 cell battery)
    Asus G751J, G751GY-T7025H
    G751JY REV. 2.0
    ASUS G751JY REV: 2.0
  5. ROBOTINCR
    ROBOTINCR Well-Known Member
    please i need someone diagram has G751JY
    thanks
  6. 28ifix
    28ifix Moderator
    cleared ME bios?
    ASUS ROG G751JY Vina.BIN
    Repair ME, Universal Edition
  8. 28ifix
    28ifix Moderator
    thank you so much boss!
  9. 28ifix
    28ifix Moderator
    This is G751JT not JY.
    flashed and checked in system, it's JT,not JY, wrong model.
    can check in HEX as well.
    do you have JY?
  10. 28ifix
    28ifix Moderator
    here is the cleared me one that i just made,tested working
  11. yuran
    yuran New Member
    Hello I have ASUS G751JY REV2.2 after BIOS update failure, now when I power on power led flash once. When I use above BIOS I can power on, but only start spinning the fans and on the screen i see darkness...
    you have a clue? I prepared my bios but also the effect of the same fans to spin and nothing more
  12. JOEL TORIO
    JOEL TORIO Well-Known Member
    hi i need help, im looking for bios G751JY 2.5 MAIN & EC please
  14. ofer213
    ofer213 Well-Known Member
    Hello everyone, i have this laptop ( asus rog g751jy rev: 2.5 ) in original chip & BIOS computer don't responding. no current pulling from m.b. i have tried to writ all BIOS from site on new chip, now it show current pulling 0.08 A from bat' socket. this BIOS i write (ASUS ROG G751JY_Vina.BIN) ; (G751JY_2.0.fz) ; (_g751jy_ECROM.bin) same result ! from charger- same thing white all BIOS. it show instead of 20 V 4.3 V someone has an idea
    check again all hardware.
  16. 13ifix
    13ifix Moderator
    need schematic
    all asus no have schematic, please keep in mind
  18. 13ifix
    13ifix Moderator
    ok
  19. ctools
    ctools Well-Known Member
    Hello friend, could you help me with main bios ec, I have main board G751JY REV 2.5, my ec bios measures 512kb. thank you
    main bios Available above but EC 512KB you can send i file old error this ?
  21. ctools
    Hello here is the 512kb ec bios
